Weird car charger question?
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Sep 22, 2019.
  1. Prius92
    Prius92 Member
    376
    95
    Iowa
    Using the OEM car charger for my Pixel 2, it charges fine with the car ON.
    If I turn the car OFF, the dome light slowly BLINKS and the phone acts like someone is unplugging and plugging the charger back in 30 times a second.
    I don't think the Prius has it where you can leave something plugged into the 12v socket with the car off, which is not a big deal, but I have no clue what makes the dome light slowly blink.
    If I need to keep the car off a few minutes, like sitting in a parking lot checking my phone, the only way to circumvent this is to unplug the phone.
    Otherwise I feel like HAL 9000 is in my dome light.
    49,371
    isn't the socket dead with the car off?
  3. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    That's my understanding too. But the dome light is live even when the car is off... The fact it's blinking points to a problem... Does the blinking depend on the car being off, or on? Or same with both... Also I have a Pixel2 phone and haven't experienced those problems. Perhaps you charger has a connection issue?
  4. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    Had the dome light been replaced with non-dimmable LED, perhaps?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    The dome light (and possibly some other internal lights too) is likely designed to come ON and stay ON for something like 30 seconds after the car is turned OFF or until a door is opened. The cigarette lighter power plug typically stays HOT during that interval.
    So.....it appears that the mechanism responsible for this delay has failed......or is failing.
