Weird ICE start-stop at bottom of hill
Discussion in 'Gen 2 Prius Main Forum' started by kinghuang, Jul 4, 2005.
  1. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    I've noticed a really strange behaviour at the bottom of one particular hill on my normal route to the airport. There's a stop light at the bottom where two major roads connect. Whenever I drive down this hill and stop at the stop light, the Prius ICE will repeatedly cycle on and off extremely quickly and continuously. IE: It'll start and stop within a second, over and over again. The first time it happened, I didn't think much of it and just let it do its thing. But, I've noticed this three separate times now, and it just doesn't seem right. Because it's after a long downward slope, the battery is usually near full (first or second green bar). I've made sure that my foot is firmly on the break, so I don't think that's it. Yesterday, when I did the same drive, I tried shifting to neutral after I stopped, which stopped the ICE from repeatedly starting and stopping. Has anyone ever heard of this behaviour? It only happens at this intersection.
    Here's a Google map of the area for anyone that's interested. It always happens when I'm traveling eastbound on Country Hills Blvd., stopped just before Shanganappi Tr.
  2. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    When you go downhill you're charging the battery. Remember the Pri doesn't like overcharge on its HV battery. So when it gets full it'll kick on the ICE to drain off excess energy. Sounds like that's what's going on.
    I believe in N the car won't charge the battery so that would keep the issue from happening.
  3. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    <div class='quotetop'>QUOTE(galaxee\";p=\"103983)</div>
    I think the effect I'm getting at the bottom of this particular hill is different. I have experienced the ICE spinning freely when going down really long hills after the battery is "full". However, what happens at the bottom of this particular hill is that after I stop for a few seconds at the stop light, the ICE will start up (on gas) and then go off in the space of a second, and do this repeatedly. Since the battery is practically full, it shouldn't be spinning up to charge it. And, it's warmed up outside now, so I don't think it's because the engine is cold. Are there any general situations where the Prius ICE is supposed to come on and off repeatedly like this?
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    It isn't spinning up to charge it, rather it is running MG1 (powered) to drain the battery a bit, but not accept any current once ICE starts up. It then shuts down ICE, then uses power to start it up again. It is like cranking a malfuntioning engine until it goes dead, but in this case, ICE is actually started. The fact that you hear ICE spinning near the bottom of the hill confirms that the battery is full, and thus HV goes to 'bleed off' mode at the stop at the bottom of the hill.
    I know, sounds dumb to me, but that's what we speculate is happening. Since the function of N is to totally disconnect drivetrain, really what it does is disable MG1/MG2 control, both to prevent powering them, or prevent receiving power from them, thus ICE cannot be started.
  5. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(DanMan32\";p=\"104150)</div>
    I wonder why it wouldn't just spin the ICE with MG1 without starting it? All it would have to do is deny the ICE gas and spark. Perhaps it wasn't designed to shut off all gas to the ICE and therefore must start it to keep from flooding the ICE?
  6. kinghuang
    kinghuang Member
    119
    Calgary, AB, Canada
    I suppose that's reasonable enough. It does seem like a strange way to drain off the battery.
    Putting it into neutral for a minute shouldn't break anything, right? After all, I'll be going up a bit of an incline again after the light goes green. So, it would make more sense to drain the battery on that than on a dead stop.
  7. robinredbreast
    robinredbreast New Member
    42
    S.W Lower Michigan
    I have had the excact thing happen to mine ICE on off on off on off until I shut it down I was coming down my long steep driveway and had to stop half way down because my cat would not move out of the way. Its not letting off a charge . I had blue bars
  8. love2drivefaster
    love2drivefaster Junior Member
    25
    Has anyone figured this issue out yet? I had this happen to me for the first time today. Similar situation. The HV battery is 1 bar from full. Im at a slight incline while parked. Weather is probably in the mid to low 60s. Car isnt really warmed up yet.
  9. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    If he did I don’t think he will tell. The OP has not logged on here in over 2 1/2 years.
  10. bisco
    49,371
    a fully charged battery requires the engine to start to burn off any excess incoming charge. as the weather gets colder, the battery accepts less charge, and the engine comes on sooner
