Weird idle noise and struggles to accelorate
Discussion in 'Generation 1 Prius Discussion' started by Mark Anthony, Apr 21, 2025.
  1. Mark Anthony
    Mark Anthony New Member
    Southern California- Rancho Santa Margarita
    2002 Prius
    Hello everyone! I have a 2002 1st Gen as my commuter car. It has 198k miles and its just now starting to have issues. 2 months ago it kicked out some misfire codes. Since then I changed the spark plugs, coils and fuel injectors. The codes went away and it ran perfectly until about a week ago. The misfire codes came back P0301 and P0304. I changed the spark plugs and coils around and still the codes came back. Now it has a "knocking" noise after a few seconds of turning on and struggles to accelerate. There is some smell of gas in the oil.
    Has anyone encountered this issue or have an idea of what it could be?
    My guess is the fuel pump... for the life of me, I cant find part number, however, i found one on ebay and ordered it not knowing if it is the right part number.
    Any help on getting a diagnose from anyone is much appreciated.
  2. ammdb
    ammdb Active Member
    275
    110
    Indianapolis
  3. ChapmanF
    17,168
    It might be hard to find a separate fuel pump part number for a gen 1. I am not sure it is replaceable except as a tank assembly.
  4. ronlewis
    ronlewis Active Member
    971
    194
    texas
    2001 Prius
    Yeah, I would clean the throttle body and MAF first in case that fixes it. So, you swapped coils and plugs around...but the codes didn't follow the parts to the new cylinder? You can try the same with injectors. But yeah, if you ordered a fuel pump, it wasn't for this car. The pump is integrated into the gas tank. If you can get the car high enough up in the air, it's not too hard to swap the tank.
    ammdb likes this.
