Weird jingling noise in rear suspension
Discussion in 'Gen 2 Prius Technical Discussion' started by Tony714, Jun 11, 2021.
  1. Tony714
    Tony714 Member
    108
    Orange County
    Hey Prius Peeps I’m hearing a weird jingling noise coming from my driver’s rear suspension area. The suspension does not feel worn so I’m guessing it’s something else.
    Anybody got any idea what that might be?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    a bell on a cat collar?
  3. Tony714
    Tony714 Member
    108
    Orange County
    that must be it. I read somewhere that these gens came with cat collars standard
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Crawl under the rear of the car take alot of pictures of suspension.See many broken rear spring from corrosion on this site. Let’s see if it’s got a corrosion issue under there.
    Jack up the rear of the car with e brake off spin the rear tires see if it’s coming from the brakes. Also take advantage of that and while spinning the rear tire
    Look at it from the back make sure there not bent. No tire run out.
    Not saying bent wheel is making the noise but I personally have had so many bent wheels on my car so I always look.
    how many miles on the car?
  5. TMR-JWAP
    6,404
    6,088
    Columbia, SC
    The answer I provided is about as good as any other you're going to get. Read your post. Its like calling a doctor on the phone and saying "I don't feel well" , can you tell me what's wrong?
