Weird noise under the hood, any help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noop, Jun 22, 2018.
  1. Noop
    Noop New Member
    Jordan
    Hello everyone, any sorry for ur time :)
    I posted a video here months ago about weird noise under the hood (passenger side unde the motor) , and i tried to record it with som poor video quality,
    Now its much persistent and louder so i took this video , and i hope its clear this time
    It starts when the engine kicks in and stays at idle, and go away when i press the throattle. I tracked it to the passenger side just beneath the motor.
    I visited couple of mechanics and they offered to take the motor apart as they cant figure out what is it coming from exactly
    Any help will be appreciated and thanks every one
    49,508
    how many km on her?
  3. Noop
    Noop New Member
    Jordan
    81k mile , 2011 prius
    49,508
    seems too young for engine problems. maybe start with the egr circuit and intake manifold. does she burn any oil?
  5. Noop
    Noop New Member
    Jordan
    No it doesn’t burn oil, and there are no warning lights appears on the dash
  6. Mendel Leisk
    38,736
    Timing chain, that runs between the crank shaft and the two cam shafts at the top, is in there, behind a cover. it has tensioners and what not.
    I would hold off; the cure could be worse than the condition. Timing chain cover seal and reinstall is VERY tricky, and in tight quarters. Just monitor for a while longer.
    bisco and Andyprius1 like this.
  7. padroo
    padroo Senior Member
    2,763
    2,250
    Mendel could be on to something. Some cars with long timing chains use hydraulic oil pressure to apply tension to the timing chain. I did one many years ago and all it was was a piece of dirt clogged a small orifice not allowing the tensioner to work.
    Andyprius1 likes this.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Which motor. ???????
  9. bisco
    49,508
    maybe try a different weight oil?
    Noop likes this.
  10. Andyprius1
    2,327
    859
    Cool CA
    or heavy water?
  11. Mendel Leisk
    38,736
    Save that for the Ford Fusion.
