weird oil dipstick
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by enginestar, Apr 13, 2019.
  1. enginestar
    enginestar New Member
    Redmond, Washington
    My 2010 Prius showed weird oil reading recently, it has 184k miles,
    What is that mean?
    See photo
    51,140
    burning, leaking, overfill
    most likely a clogged egr and blown head gasket, but not necessarily
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    There is no photo to see.
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Maybe that’s the issue:p.
    Maybe the moderators will allow the photo but if not, if the dip stick is hard to read, leave it out of the car for 5 minutes or so and reinsert;).
    If there is no oil on the dipstick, that’s a bigger issue:cool:.
    Good luck and keep us posted (y).
  5. Mendel Leisk
    40,574
    @enginestar post a few times more, what is it, 5? And then you'll be able to post a pic.
    And follow ray's advice, if it's just a matter of smearing on the dipstick, hard to judge true level. Oil gets pulled up the tube when you pull out the dispstick; waiting 5 minutes, it'll settle back down.
    Bit of a design fail, but at least there's a work around.
    jerrymildred and Raytheeagle like this.
  6. enginestar
    Redmond, Washington
  7. jerrymildred
    11,517
    14,137
    Tampa, FL
    I'm not sure there's a rule like that for pictures. I know there is for links and for not needing to have your post moderated before it shows up (which sometimes leads to some interesting post sequences).
    But either way, we'll obviously need either a picture or a good description.
  8. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    You’re not the only one. I get weird oil readings all the time. Cold soaks, always a segment of oil on the stick an inch above the full mark that’s half inch length on its own an island.
  9. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    As a new member the forum won’t allow you to post photos til post quota have been meet. You can private message me the photo, I’ll post it for you
  10. Mendel Leisk
    40,574
    probably can't private message either, lol.
  11. bisco
    51,140
  12. Mendel Leisk
    40,574
    Not sure what's going on with the circled zone, looks like something overheated, baked-on? Or just overdue for an oil change?
    Well focussed picture btw, seems like most dipstick pictures, the focus is on those boards in the background, lol.
  13. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Looks like the oil level is good;).
    As for what is above the oil level :eek:.
    Follow @Mendel Leisk ’s advice and wipe it clean and start again. Any history of issues or damage :whistle:?
  14. bisco
    51,140
    i must say, the oil looks very dark. mine is always clear on the stick, hard to see. but at 184k, idk.
    Mendel Leisk and Raytheeagle like this.
  15. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Meh, it’s not that dark;).
    I bet the oil in the sump is much darker:cool:.
    But even synthetic oil darkens over its use. Redline starts out darker as it is ester based:).
    So there could be a myriad of reasons why(y).
    #15 Raytheeagle, Apr 13, 2019
    enginestar and bisco like this.
  16. bisco
    51,140
    the oil in my sump is dark brown, but on the stick clear.
  17. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Yup;).
    Deceptive (y).
  18. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
  19. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Good catch;).
    I wrote ester but my iPhone autocorrected it to be “water”:confused:.
    Edited above(y).
  20. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I polished the dark spot off my dipstick when I did the motor swap. It hasn’t reappeared yet. That spot likely corresponds with the tube o-ring groove sealing to the pan. If dirt or road grime is building up, it can mix with the oil and stick there, especially if the o-ring is missing or damaged.
