Weird Prii '10 startup issue: sometime not in ready mode and a quick fix I found
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cb_jimmy, May 15, 2016.
  1. cb_jimmy
    cb_jimmy Junior Member
    16
    Phnom Penh, Cambodia
    My 2010 prii sometime has this weird startup issue. Occasionally, the car will not get into ready mode. Power and accessories are on but it won't move. Normally, I would try depressing the brake pedal and pushing the Start button (usually took me less than half a minute) until the car turns itself off. It would be back to normal functionality the second time it startups. Recently, I found this alternative quick fix:
    When car refuses to get READY,
    -Open the driver door
    -Depress the brake pedal
    -Push the START
    The READY light would be on and the car is set to go.
    This issue doesn't bother me that much since it only happens rarely. However, it's good to know if anyone has experienced this. What is the cause? a software glitch?
    Another thing I notice, if I use the normal method to restart the car, the battery bars are sometimes falsely reported a lot more charge (full bars) than before the car was turned off. It would then quickly drained to the actual charge.
  2. JC91006
    16,482
    8,400
    Have you checked the health of the 12v battery?
    SM-N900P ?
  3. cb_jimmy
    16
    Hmm.. I don't have a voltmeter. Guess I'll bring her to a battery dealer.
    So the 12v battery need replacing if the volt reading falls below 12v?
  4. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Is this the same 2010 that you posted the carfax on? Buying a used Prius 2010 with open recalls | PriusChat
    Prius is well known to have flaky electrical problems when the 12 volt battery gets weak. Buy a cheap volt meter and check it yourself. Check it with a load and without. Post what readings you see.
    Here is a chart for non loaded 12 volt battery for your reference. Your battery is a "AGM" type battery, so refer to the first column. It would not surprise me one bit to find your battery needs replacement. Chances are it is the original battery and therefore would be at least five to six years old.
    cb_jimmy likes this.
  5. cb_jimmy
    16
    Thank! I'll get me a cheap voltmeter. Should I let the car sit for a night before doing the reading?
    Also, please elaborate a bit about the loaded and non loaded part.
    And no, this is not the Prius I posted in that thread. The one I picked doesn't have outstanding recalls and I think I got quite a good deal for it.
    #5 cb_jimmy, May 16, 2016
  6. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    You could also check the brake switch behind the pedal.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Leave car overnight, check voltage before turning the car on. Unfortunately with a Prius this can't be done without putting some load on the battery (when you open the hatch some lights turn on, like the ones on the bottom inside of the doors). But it's better than nothing.
    For a larger "load check" turn on the headlamps without turning on the car and see what the voltage drops to. It should stay above about 11.5V at the battery. If it gets to 10V or less you have a dead cell.
    The brake lamp switch is also a good thing to check. Park so the tail lamps can be seen in a window. Press the brake pedal lightly, and the brake lamps should come on. If it requires a hard press it's out of adjustment. This can cause trouble getting to "ready" as to get to "ready" the brake switch must be actuated. If it isn't you go to "accessory" then "ign on", neither of which will allow you to actually drive away. Press again and it will go to "off". It's in the owners manual.
  8. bisco
    49,485
    pop the hood in the evening, so you can check the voltage at the jump point in the morning, without opening any doors. you like to see at least 12.4 although some will say less is okay. load test by turning on headlamps and watch voltage drop.
  9. cb_jimmy
    16
    Ok, I bought a multimeter and did the reading this morning. I'm not sure if I'm doing this right. With the dial setting as shown in the attached pic, the meter show 10 on the "&ACV" row during non loaded condition and 9 when I turned on headlight and beam.
    I suppose this is the cause of the startup issue? so the battery need to be retired? The car starts fine most of the time.
  10. Former Member 68813
    3,524
    981
    US
    LOL, lost art of reading analog gauges. with the selected range at 50 you read the scale that goes to 50. if it was really 10V, you need a new battery.
  11. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    You need "DCV."
  12. cb_jimmy
    16
    I did set the dial to measure DCV. I was just trying to point out the reading location on the gauge.
  13. dorunron
    3,318
    1,103
    Houston, TX
    If you are reading the meter correctly, then chances are the battery is indeed bad. A digital volt meter is preferred over a "analog" type which you now have.
    I would suggest changing it. Be aware that the battery is a AGM type battery AND that it has "JIS" post's on it.
    In the future, for better accuracy it is suggested that you use a "digital" meter rather than a analog meter. [​IMG]
    Be aware that is possible you may be having issues with the brake light switch also. You need to confirm that the brake lights are coming on "when" you have the problem of the Prius not entering "Ready" mode. If you can confirm that the brake lights are working "ALL the time", then it is suggested to change the 12 volt.
    #13 dorunron, May 18, 2016
  14. RRxing
    2,520
    1,791
    NEPA
    I'm still thinking it's a brake switch issue.
    cb_jimmy and dorunron like this.
