Weird question about hardness
Discussion in 'Newbie Forum' started by Garra671, Nov 18, 2020.
  1. Garra671
    Garra671 Junior Member
    44
    Wherever
    Not sure if this is right place too post this, but I’m trying to find some guide or something to show me a hardness scale?
    by this I mean, what metals will scratch other metals? Will nylon bristles scratch plastic?
    I ask because I’m getting ready too clean. EGR,MAF, intake manifold. Etc etc etc.
    and I don’t want too use something to hard that will scratch the inside surfaces.
  2. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
    The folks I know who are in the trade have a special set of small files and by using those files on any kind of metal they can give you an exact hardness rating. I suspect it it is low?
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,510
    2,490
    Taylors, SC
    Most all metals are not used in the pure state. They are alloyed with other metals. The hardness of metals will depend on the allow and the temper. 7075 aluminum, for example, is harder that 6061 and much harder than 3003.
    The same issue varies with plastics. PEEK is much harder than nylon 6-6 which in much harder than HDPE.
    PriusCamper likes this.
  4. Mendel Leisk
    41,873
    For the EGR cooler only: powdered Oxy-Clean dissolved in hot tap water, as concentrated as you can make it. Soak for about an hour, rinse and repeat. If extremely clogged, use thin copper wire as needed to open up passages, allow the solution to penetrate.
    Others have used oven cleaner, and/or pressure washer.
    For most everything else but the MAF: brake cleaner.
    For MAF, a specific MAF sensor cleaner, CRC makes one.
    No, should be fine. I use old tooth brushes, bottle brushes.
    jerrymildred likes this.
