Weird Rumble While Braking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ReallyAMatrixGuy, Jul 31, 2021.
Tags:
  1. ReallyAMatrixGuy
    ReallyAMatrixGuy Junior Member
    Utah
    Hey guys I am having a bit of an issue with my wife's 2012 prius. When braking between 40-60mph there is a weird rumble/rattle that I have not been able to figure out. It sounds as though it is coming from the front drivers side and I have already done a lot to try and single it out but to no success. I replaced the rotors and brakes thinking that they may be warped, rotated the tires, while the wheels were off, checked all of the link that could come loose, put the wheel on and shook it like crazy in all directions while I had someone under watch from behind, I even recently mounted a go pro to the wheel well while driving to try and find it, but I have found nothing and it is driving me crazy. Any ideas or anyone have any similar problem. I will post two videos on youtube with a link to them.
  2. ReallyAMatrixGuy
    Utah
  3. ReallyAMatrixGuy
    Utah
    Oh also I pulled the Abs fuses just to verify it wasn't that malfunctioning
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,033
    6,920
    Texas Hill Country
    Sometimes the hubs go bad
  5. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    i mean , audio wise, that sounds horrible.
    only between 40-60mph?
    nothing at lower speeds?
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    how old are the tires? Have you check for any bulges on the interior side of each tires?
  7. PriusCamper
    PriusCamper Senior Member
    13,419
    5,417
    Pacific Northwest, USA
    Braking at that speed is predominantly regenerative, but the transmission that handles that job rarely fail... But changing your transfluid would be a good way to investigate that. Of course without warning lights and errors codes you're trying to fix something before it's failed. I'd suggest a wheel bearing as another person has, but again that's a guess.
  8. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds like the dreaded engine rattle
  9. ChapmanF
    18,976
    Except for the way it goes away with releasing the brake pedal, and slows down with the road speed.
    Longer recordings might be helpful ... maybe a friend in the car to deal with the phone.
