Weird SOC activity
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gbru316, Apr 25, 2015.
  1. gbru316
    gbru316 Junior Member
    Lancaster, PA
    For the past month or so, the SOC has been jumping around quite a bit. I know this is normally indicative of impending traction battery failure (and so is the 205k on the odometer). Well, today it happened. The dash panel lit up like a christmas tree. Drove it home with no loss of performance. No loss of efficiency, either (avg 45 mpg, but it always averages lower in the winter/spring months).
    I pulled the +12Vdc line off of the aux battery and let it sit a few minutes. When I reapplied power and started the car, no warning lights. In fact, the SOC meter is now behaving normally. I went for a 15 mile, half hour drive and noticed no difference in performance other than a) the SOC meter is now behaving more like I expect and B ) the car turns the ICE off more. MPG average for this drive was 49.2 mpg, and it was a combo of city and highway.
    I did floor it for a good 15 seconds while merging onto the highway and the SOC meter dropped to 1 bar before rising to and maintaining 6.
    I checked the inverter fluid and the pump seems to be functioning. The aux battery (yellow top) was purchased 2 years ago.
    I guess my question is, is this actually an impending traction battery failure? If so, I suppose I should order a few cells in the near future.
  2. Patrick Wong
    18,200
    6,479
    Just wondering what speed you achieved, if you actually floored the accelerator for 15 seconds.
    Probably - but at 205K miles, unless your idea of a new hobby is to periodically open up the battery case to replace modules, you may be better off installing either a new traction battery or else 28 modules from a G3 donor traction battery.
  3. gbru316
    Lancaster, PA
    It was probably closer to 10 seconds (to roughly 65 mph). Wasn't timing it.
    The gen 3 modules are drop ins? What would be the advantage (other than that they are "new")? Really not looking to spend $1500 right now, we're trying to move this summer.
  4. Patrick Wong
    18,200
    6,479
    Yes, the main advantage is that the oldest G3 modules are no more than 5 years old, and obviously, the newer the replacements, the better. Yes, they have a similar physical form factor as G2 modules. Yes, you probably would have to spend ~$1,500. At that price a new battery from Toyota doesn't seem so bad...
  5. gbru316
    Lancaster, PA
    $2200 for brand new (MSRP minus core credit) or $1500 for one with uncertainty. I drive about 700 miles a week, it might be better to eat the extra $700 for peace of mind.
  6. Patrick Wong
    18,200
    6,479
    Definitely, if your income stream depends upon continued proper functioning of your vehicle, there is no question that installation of a new traction battery from Toyota will be the way to go.
