Weird sound in the front, no codes, so lost
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Naz M, Apr 10, 2022.
  1. Naz M
    Naz M New Member
    Toronto
    Hey guys,
    It’s Sunday so can’t bring the car to the mechanic and there are no codes showing, so I have no idea what this could be.
    The car started making a weird noise this Friday, it was hard to notice at first for me but then it got obvious. Almost a whistling sound when I press on the gas. I attached videos of what it sounds like. After startup and after I push the gas a bit.
    Has anyone had this before? Any ideas?
    Starting to get anxious that it might be an expensive fix :(
  2. JC91006
    16,479
    8,397
    How many miles does this car have? I see your coolant level is below the normal level. What type of maintenance have you done to the car?
    2010moneypit? likes this.
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Has it had a rough start in the past few weeks? Maybe a bent rod.
    49,430
    ever cleaned the egr?
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Prepare for new engine
  6. ChapmanF
    15,558
    I would call that engine sound oddly labored, with or without the hissing sound.
    I wonder what the exhaust system looks like, and what its backpressure is.
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,952
    4,707
    Texas Hill Country
    I certainly would do a top and bottom visual check along with a mechanics stethoscope inspection. AC off. Ideally on a lift with the undercovers removed.
  8. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Which device/app are you using to pull the codes with?
