Weird sounds from braking
Discussion in 'Prius c Technical Discussion' started by maverickf, Apr 22, 2012.
  1. maverickf
    maverickf New Member
    113
    Southern California
    I heard some weird sounds, it sounded like some metal dropping on concrete, when I stepped on the brake while making turns. I know in the manual it says "Sounds may be heard due to regenerative braking when the brake pedal is depressed." in P.28, but was the sound normal?
    Now, any wired sound from the car makes me nervous...... I hope it just happened today...... :(
  2. krneidigh
    krneidigh Junior Member
    70
    17
    Pensacola
    I'm going to say take it in. The regen brakes will just have an EM whine. It could be anything from a bolt came out of your caliper to a bad CV joint. Does you abs fire? Does it pull to one side?
  3. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    The ABS will kick in when one or more wheels is turning significantly faster than another while braking. That would be the outside wheels when braking and turning vs the inside wheels. The ABS computer can figure out turns and not kick in, but if you hit a bump while turning and braking it confuses the computer and kicks the anti-lock in.
  4. maverickf
    113
    Southern California
    I didn't hear that noise yesterday, but again this morning...
    I read another member had a problem and he said it was a heat shield hitting a metal transmission line, maybe I better bring my car back to the dealer and check. Problem is I need to take a day off to do so unless bringing it on Saturday.
  5. magtataho1
    magtataho1 New Member
    Delta, BC
    Hi fellow C owners,
    All 2012 Toyota Prius 1 2 3 are all equipped with Vehicle Approach Notice system which means it mimic the sound pressure of a conventional engine especially during braking.
    It prevents a danger for a visually impaired somebody or pedestrians.
    Hope it helps.
    magtataho1
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    huh...?
    i'm pretty sure the sounds described above have nothing to do with the VPNS..
