Weird Tweety-type noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cathy Flynn, Jan 21, 2020.
Tags:
  1. Cathy Flynn
    Cathy Flynn Junior Member
    Virginia
    There is a strange tweety-type noise coming from the passenger side dash. It's seemed to not be as loud when at increased speed. It's there when in Park, as well. I called Service and they've not heard of it and said to bring it in. Has anyone had this?
    52,362
    welcome!
    no, can you record it?
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I've noticed a similar noise coming from the passenger-side, behind the dash (but actually from the engine-side of the firewall) in my 2009 Gen II (163,000 miles). The noise is quite noticeable when the engine is cold and is absent after everything warms up. It sounds a bit like a dry bearing. The car is almost due for a 5k service so perhaps I'll have them take a listen when I take it in.
  4. WilDavis
    2,493
    2,155
    49
    duplicate post removed. @Danny !! there seems to be a problem with the bloody site!
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Was this for the 2017 Gen4 in your profile, or are you referring to another Gen2 in your fleet?
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    See if it changes with fan speeds. If so, check for debris in the fan assembly.
