Weld a broken egr cooler’s bracket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kuang, Feb 28, 2019.
  1. Kuang
    Kuang Member
    37
    37
    US
    Do you know any shop I can go to weld a broken ego cooler bracket? I live in Orange County, SoCal. Thanks
  2. gliderman
    gliderman Active Member
    751
    223
    Any muffler shop can weld that quickly.
    Kuang likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Just use jb weld and you’ll be fine;).
    Mine had a similar issue and it worked well(y).
    #3 Raytheeagle, Mar 1, 2019
  4. orenji
    orenji Senior Member
    5,884
    3,486
    How do these break?
  5. Mendel Leisk
    38,728
    Is that the lower bracket? In any event, I would just do nothing, and leave the fasteners off at that location; the entire assembly will still be very stable.
    FWIW: @Ragingfit, when installing 4th Gen engines in 3rd gen car, has the EGR free-spanning from the exhaust to intake manifold connection, no intermediate connections.
    Lino likes this.
  6. Kuang
    Kuang Member
    37
    37
    US
    I BOUGHT EGR from eBay and did not pay attention the break. Then I clean my car's EGR last month and replaced it with the broken one but The coolant was leak from where it broken
  7. Lino
    Lino Member
    61
    38
    Use it without welding or mounting that PIA bracket, it will be fine without it as long as there is no coolant leaking.
    If you desire to weld it that is stainless and muffler shop probably cannot weld it
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Ever see a parts yard remove parts:whistle:?
    Let’s just say that they don’t pay people to carefully remove parts;).
  9. ETC(SS)
    6,555
    You know what?
    I don't remember using JB-weld anytime in my life but this would be a perfect case for me giving it a try.
    A quick trip through the Googles told me that they make a 'steel stick' blend that's:
    -rated for stainless
    -less than $5 (maybe even in the California)
    -widely available
    -temperature and strength rated for this application
    If I woke up with this problem that would be my first solution, since anyone who is holding an EGR cooling bracket in their hand is a good candidate to attempt this type of repair.
    My fallover would be a muffler shop as mentioned above, especially out on the left coast.
    Stainless is very common in exhausts.
    Even my 2009 pickemuptruck uses this material.
    If a muffler shop can't work with stainless then they're going to be out of business before the end of the month.
    It's literally a 5-minute fix that should be less than $20.
    4x more than the JB Weld and probably only a little better....
    Of course, any competent back-yard mechanic might tell you that a bracket with 2 bolt holes will probably work with one bolt, and this 'repair' will be even cheaper and faster than the JB Weld.
    Engineers get paid to make things more complicated than they need to be, and the second bolt was probably designed as a spare.
    Good Luck!
  10. Kuang
    Kuang Member
    37
    37
    US
    I came a muffler shop and the technician just spend 1 minute to weld it and charged me $10.
    RMB, Robert Holt and Mendel Leisk like this.
  11. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I am glad to see a cheap, easy, and fast happy ending. :sneaky:
    Raytheeagle and Kuang like this.
