Well, add me to the statistics. My CAT was liberated from my Prius.
Discussion in 'Gen 2 Prius Main Forum' started by Bunce, Jun 30, 2021.
  1. Bunce
    Bunce Active Member
    321
    185
    Oregon
    So, my CAT's gone.
    If I replace it with a new cheapo CAT from Amazon, will they come back a week later and hit me again?
    Are the non-oem CAT's desirable to these parasites?
    I'll need a new CAT and O2 sensor, what's the current best options?
  2. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    Since you live in Oregon the cheap Amazon cat will work in your state. Dumb criminal will try to steal your cat again because they are dumb. I would try to buy or build a CAT shield just so you're Prius isn't an easy target next time. They have tons of threads on what kind of protection is good for your situation. I did a diy cat shield for my Prius and it's been working for 4 years now. Good luck!
    SM-A526U ?
  3. Bunce
    Bunce Active Member
    321
    185
    Oregon
    I was just reading your CAT protection thread. Very nice.
    49,397
    bummer!:mad: where was your car?
  5. Bunce
    Bunce Active Member
    321
    185
    Oregon
    Sadly, on the street in Portland. I'm staying at a friends house and there's no room on the driveway.
  6. bisco
    49,397
    i'm getting nervous about going anywhere these days
  7. JC91006
    16,479
    8,395
    They will not steal an aftermarket CAT if you make it obvious that it's not original. I would spray some green/orange bright color spray paint on the new one. Good indicator it's not original and they'll leave it alone
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,156
    2,207
    Taylors, SC
    Don't blame you. Get protected! It's cheap.
  9. Bunce
    Bunce Active Member
    321
    185
    Oregon
    Like brake caliper paint? Or?
  10. JC91006
    16,479
    8,395
    Anything bright, spray paint, it doesn't matter. It alerts the thieves to take a second look (some thieves are stupid) and don't waste their time on something not original
  11. Georgina Rudkus
    3,156
    2,207
    Taylors, SC
  12. Bunce
    Bunce Active Member
    321
    185
    Oregon
    It would need to be heat resistant. CATs get bloody hot.
  13. Georgina Rudkus
    3,156
    2,207
    Taylors, SC
    view from front.JPG The VHT is just fine, It's been on there for a year.
    edthefox5 and Bunce like this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    GR for the win.
    Use the header paint she specified I did and a year later the paint is still on it. Use regular paint and won’t last long. Cats get extremely hot.
    Georgina Rudkus likes this.
  15. edthefox5
    10,096
    4,805
    Clearwater, Florida
    The cat I got off Amazon last year had a figment issue that worked out really well for this application. The end of the Amazon cat pipe is bigger than the stock pipe so my welder used a metal bushing in that junction resulting in that pipe area Being Twice as thick as just the thin stock pipe. It will take a lot more time and work with a sawzall to cut through it and a plumbers copper pipe cutter will not work. It’s also painted orange like GRs pic.
    It’s the $125 cat on Amazon. Been on my car for over a year still running good no codes.
