well it finally happened, engine sound like loose bolts in a can
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cobradb, Feb 16, 2013.
  1. cobradb
    cobradb Member
    105
    tn
    happen after 60k miles during start up. hasnt happened again (6k later) ....i thought it would never happen to mine.
  2. Tande
    Tande Active Member
    502
    302
    Mich.
    Welcome to the "Hammer/Club".......
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard and enjoy the noise. Be sure to report it to your dealer and/or Toyota care.
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    What can it be?
  5. samdaman
    samdaman Junior Member
    75
    Eastern PA
    Water which had condensed in the intake manifold after an incomplete warmup cycle in [un]favorable atmospheric conditions, and which gets sucked into the cylinders during the next start-up. So they say. A back-yard way to blow out the carbon in your 50's junker [or blow out a rod, a head-gasket, etc...].
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    ^^ Aye. To reduce the chance of this occurring simply allow the engine to complete the first stage of the warm up cycle before turning it off. I.e. do not start the car, back it out of the garage and then immediately turn it off. Allow the engine to turn itself off before shutting the car down.
    If you need to move the car a very short distance it is better to push the power button and immediately put the car in EV Mode. Move the car and then shut it off without the engine starting.
    xpcman likes this.
  7. Mendel Leisk
    38,726
    ^ And if EV's not available, which is often the case, you've got the 15 seconds or so of mandatory EV, if you move fast you might dodge engine start up.
