Well... It finally happened....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DarkPri503, Apr 3, 2015.
  1. DarkPri503
    DarkPri503 Junior Member
    68
    Salem
    I've had this 2005 for a couple years now, clocking in almost an even 50k, without any hitch our issue (except a dead 12V).
    We just got our 5k oil change a couple weeks ago at Toyota, again no hitch.
    The wife was driving it this morning and boom! check engine light :/
    Going in for diagnostic. Wish us luck.
    Anyone have a guess to what it could (probably/possibly) be?
  2. JC91006
    16,482
    8,400
    check engine lights are usually emissions related.
    loose gas cap, bad oxygen sensor, bad catalytic converter, bad spark plugs and coils, dirty throttle body, dirty maf sensor, dirty air filter.
  3. ChapmanF
    15,615
    If the light you mean is literally the check engine light, the yellow engine shaped one, then you're probably looking at one of the possible trouble codes that are detected by the engine control module. There are a lot of possibilities, so it's sanest just to wait and see what codes are read out when asking that module what it's complaining about, but they're mostly all the same possibilities you'd see with any similar gasoline-engine car.
    -Chap
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Well with that much revelation and specifics..I can say without a doubt your problem at this point is....
    Your Check Engine Light is on.
    Good Luck.
    Merkey and Mendel Leisk like this.
  5. Mendel Leisk
    38,726
    When you get it checked please post an update: codes, what the problem was.
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    If it's still driving you are not too bad...
  7. bisco
    49,490
    all the best.
  8. The Electric Me
    9,083
    5,798
    Not necessarily true....
    Hopefully true..possibly true...but not necessarily true.
  9. JC91006
    16,482
    8,400
    serious issues are usually "flashing" check engine lights......that would require you to pull over asap. Constantly on check engine lights are not as bad.
  10. ChapmanF
    15,615
    I should have mentioned here too, most of the trouble codes that would light the check engine light are codes that will be readable by any OBD-II standard scan tool (think friendly neighborhood AutoZone, etc.) in case you don't have a scan tool of your own and could stop by and have the codes read on the spot, and end the suspense for all of us (and yourself).
    -Chap
  11. DarkPri503
    68
    Salem
    Hey guys thanks for all constructive ideas! :) So the saga continues. This morning, two days after the check engine light (to reply to a post, yes it was just a solid engine indicator light, not the triangle "!", phew) I fired it up and no check engine light. About 20 min after my drive, the light came back on. I'll definitely be going to Autozone tomorrow to see what code it throws. I will keep you guys updated.
  12. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Survey says ...
    My money is on P1121 - 3-way coolant control valve. Intermittent (seconds, minutes, houra, days) duration and reappearance, and a known part to fail producing an intermittent CEL. Hopefully it is this part, as the total repair cost isn't so bad.
  13. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    did they under fill when they did the oil change ?
  14. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Op, get ready for another 50k reliable driving!
  15. exstudent
    2,213
    901
    Torrance, CA
    Under the impression OP is second/third owner. Previous miles + 50,000miles he accumulated = future expected 3-way coolant control valve life span.
    Mine lasted 121,454 miles; original owner too. Hopefully everyone's lasts this long or longer.
    #15 exstudent, Apr 5, 2015
  16. DarkPri503
    68
    Salem
    DING DING DING ExStudent! Correctomundo!
    P1121 thrown, so it looks to be the three way valve. I'm guessing it being ten years old, the TSB will not be applicable for a free repair haha. Also, I read somewhere, like Bingee mentioned, if the coolant is low it might throw the code. My worry is WHY would the coolant be low. I'll have to follow up with Toyota to see if they didn't check the coolant, and it's a little cold now, but I'll be checking its leveling as well
    Thanks for sticking around guys... The saga continues! Be back for more, and I hope you're right Ex, I will take this sort of repair every 50k any day! :)
  17. DarkPri503
    68
    Salem
    sorry for the late update. Got the valve replaced at toyota and also got the coolant flushed and replaced. It was a little pricey but i've saved so much money driving this baby, I was happy to get her purring again.
    Dino33ca likes this.
