Well, time for ChuggyPig to go in for a service...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WilDavis, May 27, 2014.
  1. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    ... (just change oil & filter & rotate tyres plus state-inspection), I'll replace the engine and cabin air-filters myself, but is there anything else anyone would recommend or warn me against? Thanks in advance! - Wil
    49,721
    i would warn you against anything else! but i don't know what your mileage is.:cool:
  3. WilDavis
    2,492
    2,153
    49
    ~88k
    DROID4 ?
    49,721
    have you done the tranny fluid?
  5. WilDavis
    2,492
    2,153
    49
    ...not since I got the car back in Jan (this year). It might have been done before I got it - I suppose I should check the service record. Is that something I might be able to do, or is it better left to the dealer?
  6. bisco
    49,721
    i haven't done it, but the people who have say it's easy. two plugs, one for drain, one for fill, fill it until it starts to run out.
  7. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    +1 on the transaxle fluid. 4 bottles of WS-ATF from Toyota. What comes out will be black if it has never been done.
  8. WilDavis
    2,492
    2,153
    49
    ...I just checked the service record (on the Toyota site) and the 80k service was done just before I got the car. Looking back through the records, all the major services were done, but I did not see anything about changing the transmission oil. I understand how to do it from your post, although I don't have access to a lift, pit, or axle-stands. I just wonder what is the recommended interval for tranny-oil change? Thanks again for all this useful info. - Wil
  9. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    Many recommend doing it every 60k. There is some evidence that the first change gets most of the stuff, and later changes might be able to last longer. LusciousGarage seems to recommend it every 30k.
    It probably hasn't been done, and I would recommend it.
    WilDavis likes this.
  10. WilDavis
    2,492
    2,153
    49
    Thanks for the sound advice!
    DROID4 ?
