Went from 53mpg to 44 one one tank.
Discussion in 'Gen 3 Prius Fuel Economy' started by Gasitman, Oct 27, 2009.
  1. Gasitman
    Gasitman New Member
    118
    Washington
    I always use shell, or Costco gas and I have gotten between 50-53mpg. I was somewhere I had to fill and I went to a Citgo and now I am 44mpg per tank. How can the gas be that bad to drop so much? With the exception of Sunday, I am traveling the same route everyday as I had been.
    Only thing I can think is the defroster has been running a lot with the rain, but would I loose that much mpg?:eek:
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Re: Wth, went from 53mpg to 44 one one tank.
    You really should only see a couple MPG difference IMO. I know that the gas formulations are changing sometimes at this time of year and there is more Ethanol (upt o 10%) but that should not have made that much difference.
    I have been reading some of your posts about mileage, and am not sure why you have such a spread in MPG's? Did you reset your TRIP B odometer at fillup and are watching from a reset??
    Have you been taking any more short trips? Colder Temps?
    :confused:
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Did your other tanks involve the same amount of rainy conditions? Rain and wind can kill your milage like no other!
  4. Tideland Prius
    16,195
    cooler weather, winter fuel (maybe your last tank was on summer fuel), defroster (which means A/C is running but then again the new A/C is a lot more efficient)
  5. Gasitman
    Gasitman New Member
    118
    Washington
    I reset it before I move from the pump. And yes, there is much more rain than before. I cannot believe the defroster, with the AC running would tank my mpg. I don't know, I just cannot see what I am doing wrong, I run the same 77 miles everyday, and nothing more. That is with the exception of Sunday, but I cannot see how that would make a difference, considering it was my same route, just with 25 miles less, I ended up not going to my second destination as I do the rest of the week.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I have lost about 4 mpg since the end of summer. Hard to see why you lost 9. You might start your tank over with costco gas and see what happens.
  7. Tideland Prius
    16,195
    I'd say outside temp more than anything. I went from 4.0 to 4.4 (59 to 54mpg) thanks to temps cause the engine has to run longer to warm up. No defroster use yet and I have the grille blocked.
  8. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I have to agree my fuel mileage has dumped in the last two weeks. Temperatures are down twenty to twenty five degrees in the morning and it was been very rainy. Add to that I have a tank of E10 in the car and there is almost no way to win.
    Last tank with temperatures higher by fifteen of more degrees and a tank of straight gas I averaged 53 mpg (HSI display). I'm lucky if I'm averaging 48.5 mpgs right now. It is so frustrating not to be able to raise my fuel mileage on my daily trips around town.
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That alone could explain your problem. Rain can tank your milage because you are using energy to pump water from the tread in your tires. This is wasted energy and you pay for it with petrol. :(
    If you had headwinds aw well you would suffer even more loses. Bad weather can be almost as bad as going up hills. lol
  10. Gasitman
    Gasitman New Member
    118
    Washington
    but 9mpg??????
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Sure. If the conditions are bad enough. I've dropped from 50mpg to 39mpg just having to drive through a major storm.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just to double check, you did check you tire pressures right?
    Rain really does make a difference. It has been wet here for about 4 days straight and I was down to 53 computed. Then after it dried up on Monday and even though it was cool (30s), I was able able to get 63.8 on a stretch I was normally getting around 57-58 on. I would agree the rain and wind seem to have a greater impact than cold. But it hasn't gotten really cold here yet. More on that later.
  13. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Absolutely! I agree with F8L and others. I would bet my farm (if I had one) that the gas brand has nothing or little to do with your MPG drop. Rain and colder temperatures are the perfect combination for a MPG drop, second only to speed.
    It's too early to come to any conclusions, but based on my weekly 350-mile travels, if you drop your cruising speed from 75 MPH to 65MPH you can get an improvment of 8-12 on your MPG in the same conditions. Amazing!
  14. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    It seems obvious to me that it is a combination of things each costing an MPG or two.
    Cooler temps
    Rain
    Defroster
    Winter fuel
    The prefect storm.
    The Prius is like a category 5 hurricane. A CAT 5 HURRICANE requires an almost perfect set of environmental conditions to maintain that strength. Any change in those conditions will rapidly weaken the storm. A category 1 or 2 storm can survive all kinds of wind shear, cooler water, limited land crossing and still maintain much of its original strength.
    So yes, the things listed significantly effect the mileage of the Prius and much more than an average car. But that's because the Prius, like the Cat 5 hurricane, operates at a much higher level of efficiency to begin with.
  15. Gasitman
    Gasitman New Member
    118
    Washington
    Yesterday I filled up at my normal gas station, and guess what, even with the rain, I am back at 53.2 mpg.:rockon: I must of had some bad gas.
  16. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Although weather definitely does have an influence, it could have been bad gas. With a previous car (I don't remember whether it was my 2006 Prius or the Infiniti I had before that -- I think it was the Infiniti) I had filled up with Citgo at a 7-11. The next day, it wouldn't start! I had to call AAA to get it started, and he speculated that it was bad gas. Needless to say, I never returned to that gas station.
    A couple of weeks ago, I need to get gas and I filled up at a gas station -- it was a brand name, Chevron, I think -- that was the most convenient to get to at the time, but the station seemed a little run down. I saw my gas mileage drop immediately. There might have been other factors, such as hills, red lights, and so on. But I think the gas did have an effect.
    I usually look for a station that looks clean and well maintained. There might be some differences between brands, but probably not.
  17. richard schumacher
    7,663
    1,040
    United States
    Almost certainly the colder weather. Don't hyperventilate over this. The results of one tank mean very little.
  18. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I noticed a 3-5 MPG drop in mileage since the the beginning of the month. Oregon is a all year 10% Ethanol gas state. The winter formula gasoline has even a lower BTU per gallon. I sure miss the old days with regular gasoline.
    alfon
  19. Gasitman
    Gasitman New Member
    118
    Washington
    In Washington we only recently went to the 10% ethanol stuff. Only Arco and 76 ran it before, now everyone does. I wish when I bought gas, I got gas for my money.:suspicious:
  20. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    This is a most interesting thread, and very thought provoking.
    I too have detected a small decrease in my mileage the last two tanks. My routine is not as regimented as those that drive the same distance each day, but I can see the impact. For many years (long before I bought a Prius) I closely monitored my mileage .... I concluded that you take a tremendous "hit" with Winter blend fuel . Speed, however, is probably a larger factor; rain certainly does create more drag as well. I spend one full day in Yellowstone NP where the speed limit is 45 mph. I drove a steady 35-45 mph all day (with frequent stops). I filled up that morniing and again that evening. The calculated mileage was 65.7 mpg. The Prius is capable of delivering tremendous efficiency, but few can drive within the limitations. The EPA figure is a good guideline for normal driving, but external weather and geography .... and traffic, certainly do impact the fuel efficiency. BUT, these same factors impact all other cars on the road. Find some comfort that even though your Pries is down a bit ... so are all the other cars.
