Wet Black Oily EGR Pipe (NOT dry soot carbon)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pearl2010, Oct 24, 2020.
  1. Pearl2010
    Pearl2010 New Member
    Colorado
    I have a 2010 with 200,000 miles that is "new" to me. Bought from original owner. I drove it about 1000 miles after purchase with no problems and just watched the oil level because I knew that consumption was an issue with these. It used a little oil (like 1/2 qt in 1000 miles) but otherwise ran great. I then had a CEL and had the P401 Code. Did my research here and pulled EGR cooler, valve, pipe, intake, and throttle body. I cleaned them all very thoroughly per people's instructions here on priuschat. At that time they were clogged with black powdery soot/carbon. When I put everything back it was totally clean. At that time I also installed a new PCV valve, new OEM Denso plugs, and had run BG EPR prior to previous oil change, added BG MOA to current oil (Mobile1 0W-20 high mileage and filter), and ran BG 44K through fuel tank. I also installed an Oil Catch Can after the PCV valve. I noticed after my cleaning, the prius started consuming more oil, like 1 quart in 500 miles. I pulled the EGR pipe again to see how it was after the cleaning, etc. and it was coated in sticky, black stuff. I have paid attention and the coolant level has stayed constant and the car runs great and is still getting 46mpg in city, and mountain driving. Don't really understand why there would be wet black coating inside EGR pipe. Any thoughts, help?1?1?
    mikey_t likes this.
    51,155
    might the valve itself be inoperative?
    pjksr02 and Mendel Leisk like this.
  3. Mendel Leisk
    40,584
    Toyota part, or?
  4. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    You'd think that if you have a catch can, the oil must be getting around the rings. Any smoking, or residue at the exhaust pipe?
    How did you go about cleaning the EGR cooler?
