Whaddya mean I can't....
Discussion in 'Gen 2 Prius Main Forum' started by The Root, Feb 27, 2008.
  1. The Root
    The Root Desert Dweller
    42
    Arizona
    I've had my Prius for about ten days and am loving it. I really like the smart key system. Today I returned from a few errands, pulled into my garage, walked up to the door to the house and...It did not unlock all by itself!!! Amazing how fast new habits are formed. :doh:
  2. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    Here's a smartkey question....
    Suppose I have my smartkey in my bag...I put the bag in the car from the apssenger seat and walk around to the driver's door...any chance of getting locked out at all?
    Or I leave my briefcase in the car when I get out at work and walk around to passenger side?
    With the car off and key in car, will it lock up?
  3. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    There is no key, so no, you have to push the button on the Remote or the door to lock the car up, but I believe if it senses you put the Smart Remote in the slot and are trying to lock the doors, it won't let you. Is that right?
  4. duanelaugh
    duanelaugh New Member
    57
    Bradenton fl area
    I think that is correct....it will give you a long beep to warn you.
  5. kimgh
    kimgh Member
    297
    San Jose, CA
    I know that it's correct, as I've had the experience of not being able to lock the car because a key was left inside.
  6. BigJay
    BigJay reh reh REH reh Torture them!
    2,937
    554
    DFW
    How do you activate the smartkey system?
    My dealer told me to put the key in, and start the vehicle while pressing the button under the steering wheel. That didn't work. Any advice?
    I need an owner's manual, that's what I get for buying used.
  7. NaptownPrius
    271
    Napolis, Merlin
    I understand if it's in the slot, but what if it's in a bag in the car.
    So you close the door, lock it....wait 3-5 seconds and then it can unlock as the key is "near"?
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    You shouldn't have to have the key inserted, using the button alone should activate/deactivate the system regardless the location of the key.
    If the car is supposed to have the SKS and it isn't working you need to take it back to whomever sold it to you and get it fixed.
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    If you try to lock the car with the key fob in the car, the car will warn you with a long beep and will not lock the doors.
    However, there are some areas where the RF signal may be too weak to be detected and/or there is interference so the key fob is not detected by the SKS. I know this because on a trip, I had one fob and my GF had the other fob. She left her bag behind the front passenger seat in the car. At one stop, I was able to lock the car with the door handle button (my fob was on my belt loop). At a different stop, I was not able to lock the door until I figured out that she had left the fob attached to her bag.
    So, normally you can't lock the fob in the car, but don't count on it.
  10. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
  11. richard schumacher
    7,664
    1,045
    United States
    You also need the scheduled maintenance guide, a separate document. They will each save you money and bother. Buy them from a dealer or online.
