What’s that noise?!?!?!?!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Dec 22, 2019.
  1. Ianmeister
    Ianmeister Active Member
    314
    317
    Meridian Idaho
    Hey all! It’s time to play your favorite game, What’s That Noise?!?!?! So the car is a 2006, 220k miles. In California. Warmed up it will make this noise rhythmically at stoplights or while parked either in drive or park. Can’t tell exactly where it’s coming from. Any ideas? I uploaded it to YouTube since the file option only allowed images.
  2. Patrick Wong
    18,200
    6,492
    An intermittent pump noise typically is produced by the brake actuator pump maintaining pressure in the system. If you repeatedly depress the brake pedal while the Prius is READY and get that noise, that is proof the sound is from that actuator pump.
  3. Ianmeister
    314
    317
    Meridian Idaho
    hmmm, the thing is that it never made this noise prior to this month.
    51,141
    probably the actuator on the way out
  5. Ianmeister
    314
    317
    Meridian Idaho
    oddly the noise has stopped. hmmmmmmmmmmm
  6. bisco
    51,141
    what noise?
  7. Ianmeister
    314
    317
    Meridian Idaho
    If you click the YouTube link about half way through there’s a pump-ish noise
  8. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    AC compressor cycling? That's normal. Turn off AC if noise stops then it was that.
  9. Ianmeister
    314
    317
    Meridian Idaho
    A/c is off. That’s not it.
  10. valde3
    2,002
    746
    Finland
    What point of the video is the sound at? Voice from 00:07...00:10 sounds exactly like air conditioning.
  11. Ianmeister
    314
    317
    Meridian Idaho
    Hmmmm. I’ll look at it a little closer.
  12. Ianmeister
    314
    317
    Meridian Idaho
    Well I’ll be darned. It was the ac compressor! Is that a normal noise for that ?
