what 12v battery will fit and be adequate in '06 Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brin wood, Jan 12, 2015.
  1. brin wood
    brin wood Member
    100
    upstate NY
    what size in cca and other specs does my '06 require?
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    This is one choice, I currently have had this unit in for about 3yrs.
    Exide Edge FP-AGM51JIS
    440 CCA; 75 MIN RC at 25A
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    905
    506
    Cow-lee-fornia
    2023 Prius
    I've read and heard that the 12V is only used to boot the ECU. After that, the HV is then used to start the ICE, so CCA doesn't matter too much.
    I went with the Optima on my 2004.
    49,730
    the oem is also a good choice.
  5. PriusGuy32
    1,417
    512
    Harrison Township, Michigan
    I replaced my OEM with an Optima, it went bad after a short while, did a warranty exchange for another Optima and that one went bad within a year.
    I ended up buying an OEM YUASA battery at the dealership. Yes, it was more expensive that the Craptima. But It has given me zero problems and comes with a good warranty too. I second the recommendation for the OEM battery.
  6. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    I went w/ OEM.
    • 7 year warranty: 0-24 months 100% Toyota pays, 25-48 months 50% proration, 49-84 month 25% proration.
    • Lots of Toyota dealers near me, so a warranty claim would be easy; MUST have original receipt for warranty.
    I upgraded the non-smart key 12V battery (35 Amp Hr), to the larger smart-key battery (45 Amp Hr).
    Here is the post w/ price, part #s, and pictures: 12V Battery Upgrade: non-Smart Key (35A h) to Smart Key (45A h) | PriusChat
    If you are upgrading a non-smart key 12V battery to a smart-key battery, you could save a few buck and simply cut the battery tie down tray to accommodate the larger battery; this will be obvious when you try to fit this larger battery. Discovered this after the fact. You'll also want to have something taking up the space, so the battery doesn't slide forward/backward; ie scrap piece of wood, cut to size, to fill this void, which the proper bracket would do.
  7. GregP507
    GregP507 Senior Member
    3,002
    480
    9 D-cells in a cardboard tube would be adequate for me.
  8. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    How long would there life be in a Prius? Charged at faster than 1C and to voltage of 1,6V per cell.
  9. GregP507
    3,002
    480
    Probably the life of the car.
  10. valde3
    2,002
    745
    Finland
    You do remember that (normal) NiMH is 1.2V nominal, 1.5V at 100% charge, and shouldn’t be charged faster than 1C.
  11. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    OEM or Exide seems to be accepted by most as the best option
  12. GregP507
    3,002
    480
    This has been a tongue-in-cheek reference from the beginning. Sorry if you missed the memo.
  13. bisco
    49,730
    i think 8 d cells would be adequate.
  14. GregP507
    3,002
    480
    Right, but the system voltage of 14.2 would be harder on 8 cells than it would be on 9.
  15. bisco
    49,730
    good point. what if you disconnect after start up?
  16. GregP507
    3,002
    480
    In this whimsical scenario, I suppose that would be the real-world test (of disconnecting the battery while it's running) that many of us have only talked about. My bets are that you wouldn't notice a thing.
  17. bisco
    49,730
    you could run some wires to a switch on the dashboard.
  18. GregP507
    3,002
    480
    If I were obsessed with this idea.
  19. bisco
    49,730
    exactly. it could be the solution to the whole 12 volt battery thing. of course, you'd have to remember to throw the switch when powering down, or else you'd lose some data. i wonder how long 9 d cells will last with the current drain.
  20. GregP507
    3,002
    480
    Not very long, but in my case I don't use acc-mode, only ready-mode, so it wouldn't matter.
