What a difference a tailwind makes!
Discussion in 'Gen 3 Prius Fuel Economy' started by kgall, Sep 28, 2010.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    So yesterday I got on I-40, set cruise at 72 and reset trip A odometer.
    Over the relevant stretch I usually get about 51 mpg indicated (about 48-49 real) when I do this.
    But yesterday, I got 60 mpg indicated (about 57.5 real).
    I don't have an anemometer (sp?), but I did notice a real tailwind, based on how those huge flags some businesses fly were flapping. Other than that, I can't think of any reason for the improvement.
    Does this amount of improvement based on wind sound reasonable to the engineers here?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I have observed the same thing several times. Wind usually comes from the West down the Columbia River Gorge, with a strong headwind I might only get 35 MPG going the 200 miles to Portland. If the wind is still blowing on the return trip I might get 55 MPG or more. That is at 65 to 70 MPH, at slower speeds I don't think the difference would be as much.
  3. fuzzy1
    10,172
    That sounds reasonable to me, though I'm not the right kind of engineer to make the judgement.
    My fuel sucking pig Subaru, which gets 27 mpg in good summer conditions without hypermiling, and 33 mpg in the summer of 2008 with mild hypermiling, managed a 38.8 mpg tank (325 miles) on one run in large part due to strong tailwinds.
    Like the Prius and Civic hybrids, my Suby seems to have a sort of super highway mode, but it is normally too slow to be useful. That day's wind assist boosted that mode up to 56-60 mph on many road sections, and I was using a ScanGauge to take full advantage of it.
  4. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    I used a strong tail wind to pull a 60 mpg segment from my 08 Honda Fit with automatic transmission (flat towable). Drove up the hills and glided down engine off. It normally gives me 40-42 mpg. Prius automatically kills fuel flow, so you get a similar result. Less percentage improvement since the Prius EPA number already is raised by built-in engine off Prius design.
  5. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
  6. kgall
    kgall Active Member
    984
    152
    OOOH yes, the Columbia River Gorge is a great wind tunnel for this sort of test! That and wind surfing, though I have never tried the latter.
  7. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Kgall, I travel 167 north and south during the year (80 miles RT daily) and I'm amazed at how the wind makes a difference in mpg.
  8. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    I drive 50 miles each way up and down highway 75 in Oklahoma which runs 100% north/south. When we get southern winds of about 20 MPH constant, my mileage on the way home is in the low 40's. Mid 60's if it's a tailwind.
  9. Canard
    Canard Member
    208
    38
    Ontario, Canada
    I find it helpful to think of tailwinds at highway speeds not as wind pushing from behind, but as more of a lessening of the headwind. For example, a 40 km/h tailwind while driving at 100 km/h, means you're driving 100 km/h but pushing just 60 km/h worth of wind.
    I scored a 3.1 L/100 km last weekend over ~100 km doing this; but was penalized 4.6 L/100 km on the return run, heading back into the wind. :) Yes, wind makes an immense world of difference! Nearly 300 000 km worth of travel in a 40 hp Diesel flat-backed smart has taught me this. :)
    -Iain
  10. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Had a decent tailwind 75% of the way in to work this morning...
    End of (28 mi) commute indicated 57.6mpg! Best I've seen so far.
    Hopefully it will change directions or die down before I have to head home :eek:
  11. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I pass a public park with ball fields that has flags flying on my daily commute. Whenever I see mpg above or below my normal average I always check the flags to see the wind speed and direction.
    A headwind and I see anywhere from a 1-5 mpg decrease and with a tailwind about the same increase. It is really nice on the drive home since I have an overall downhill drive and with a good tailwind I can really see some good 55-65 mpg stretches.
  12. ny_rob
    1,968
    813
    L.I.- NY
    Somewhere in the Gulf region an oil baron sheik is beating his chest crying .... "65mpg- curse you Toyota!" :D
  13. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Thats why round trips are the best way
    to calculate trip mpg's. You may get 65 mpg
    one way and only 45 mpg the other, due to
    wind or elevation.
  15. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    True most of the time but........
    my wife has a commute that due to local weather/wind patterns gets little to no aid from a tailwind in the morning but a strong headwind on the afternoon return leg. Kinda' like folks who commute east in the mornings and west in the afternoons, the sun is always in their face. :(
  16. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I have this same problem. Most of the time in the early morning hours of my commute to work there is usually very little wind. In the afternoon drive home there is normally at least some amount of wind. So it very seldom cancels out between the two trips.
    At least my commute is east to west in the morning and back east in the afternoon so no sun in the face:)
  17. ghosteh
    ghosteh Member
    146
    57
    Illinois
    The photo in my sig was taken after several hours of driving (mostly highway, some city) with a tailwind. The route is one that I take a couple times a month. Normally, I'll get 51-53mpg.
    So YES! A very big difference based on wind direction.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
  19. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    What I need is a commuting route that is downhill one way, with a tailwind the other.
  20. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
