What a misery.
Discussion in 'Gen 3 Prius Main Forum' started by Mike72903, Sep 18, 2023.
  1. Mike72903
    Mike72903 Junior Member
    57
    Fort Smith, Ar
    Taking out the brake master cylinder assembly that is. My 77 year old body is going to hurt tomorrow if how it feels now is any indication. My question involves the dash panel that’s under the steering wheel. If I take that off will it provide better access to those 4 nuts on the firewall maybe using a long extension? Be handy putting the replacement in. If so, HOW DOES IT COME OFF? It’s hooked on 4 metal tabs underneath, but that’s the only place I see and that’s probably the final connection to remove it. This is a 2010. Thanks.
    52,004
    i'll give you this much, i wouldn't attempt that at 68. all the best!
    Mike72903 likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,170
    6,324
    Texas Hill Country
    Four 12mm from under the dash near the steering while plus the pin connecting the brake pedal.
    See
    kc410 and Mike72903 like this.
  4. Mike72903
    57
    Fort Smith, Ar
    Anyone have advice on how to remove that panel under the steering wheel? Not the wheel shroud but the dash colored panel beneath it.
  5. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Is this what you mean?...
  6. Mike72903
    57
    Fort Smith, Ar
    The small dash colored panel under and behind that. IMG_1181.jpeg I don’t want to break something by forcing it.
  7. RRxing
    2,546
    1,822
    NEPA
    Be very careful. That part is the Driver Side Knee Airbag assembly. See Step #31...
    kc410 likes this.
  8. Mike72903
    57
    Fort Smith, Ar
    Thanks for that. I’m not going to mess with it then. Just man up and crawl back under the dash.
    kc410 likes this.
