What about... a hybrid motorcycle?
Discussion in 'Fred's House of Pancakes' started by Kacey Green, Aug 26, 2004.
  1. Kacey Green
    Kacey Green Member
    112
    Gainesville, FL
    What about a mild or full gas-electric hybrid motorcycle?
    The only problem I see is the ICE and motor/generators would need to ramp up or down instead of just starting and stopping. Or you could attach a flywheel to the power split device to balance out the tourqe from the ICE or Motor/Generators starting/stopping.
    Of course, the multi-display would either need to be smaller or helmet mounted HUD, or a non interactive multi-display, or you could interface with a joystic on the handle bar (like a cell phone joystick)
    Thoughts ...?
  2. Gurmail
    Gurmail Member
    247
    Oakland, CA
    Good idea!! I don't know about the battery weight but the battery will probably be much smaller.
  3. Kacey Green
    Kacey Green Member
    112
    Gainesville, FL
    don't forget that if it is a full hybrid al-la HSD technology, it won't have a transmission, just a smaller PSD, potentially offseting the weight of the battery, or making the whole arrangement lighter, we should get some of the cycle companies to contact toyota, with the understanding they'd have to figure out a solution for the tourqe
  4. Kacey Green
    Kacey Green Member
    112
    Gainesville, FL
    I'm re-title-ing the post
  5. LungCookie
    LungCookie New Member
    67
  6. bigbaldcuban
    bigbaldcuban New Member
    599
    Mansfield, TX
    180 MPG? What the heck am I doing drivin this 45 MPG gas guzzler?!?!?! :)
  7. Kacey Green
    Kacey Green Member
    112
    Gainesville, FL
    no not at all like that, I'm with john on this topic, increase efficiency and decrease emmisions, not one or the other that bike uses a diesel. I've come to the conclusion that a mild hybrid isn't going to be good enough even on a bike. the ecycle is a full hybrid somehow even though it only has one MG
    Hybrid Synergy Drive uses two or mo Motor/Generators and the toyota power split device.
    it could have a third motor in the front spoke on a crotch rocket, or on a cruiser it could use the prius engine and MGs, (plus stealth would be even more fun). a simplified multi-display and interface, the prius gear shifter, (in a thumb toggle) as long as the engine didn't go straight to full speed there shouldn't be any balance issues. a trike could be the same as the cruiser but with the full prius interface,drivetraine and engine (except in rear wheel drive configuration) thoughts ...?
