WHAT ACTUALLY RATCHET UP THE ODOMETER?
Discussion in 'Gen 2 Prius Main Forum' started by Dxta, Jan 25, 2018.
  1. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Well, dont know, if this right place to post this though.
    I have being wondering, what actually rachets up the mileage of Prius cars.
    I do know that for conventional cars, its the VSS om the transmission.
    But if you known a PHEV, or BEV, what do you think contributes to the odometer reading? Is it the engine, or what?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Prius and most of newer (including conventional) cars just use the speed from wheel speed sensors.
    In a gen 2 Prius skid control ECU calculates the speed from wheels speed sensors. It then sends that information to combination meter that then sends the information to other components.
    uart likes this.
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    @Elektroingenieur could probably tell us. I suspect it is sensors on the wheels or transaxle output shafts that provide the signal that is converted into distance traveled.
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    That's what I think too. Speed sensors on the trans axle, or maybe the differential, in some trucks.
  5. valde3
    2,002
    745
    Finland
    You can just look it up on the manual. It does use the wheel speed sensors.
    On the combination meter diagram there’s an arrow from Skid Control ECU with vehicle speed signal marked on it.
    On the diagram of Skid control ECU there’s an arrow from wheel speed sensors. There’s also an arrow to combination meter with vehicle speed signal marked on it.
