What am I looking at?
Discussion in 'Prime Main Forum (2017-2022)' started by will the engineer, Sep 12, 2019.
  1. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    so I pulled the chargring head unit out and I see this .... a white plastic stringly thing. looking at the attachment, see the inside of the top right circle.
    it melted????
  2. mr88cet
    mr88cet Senior Member
    2,306
    1,331
    Austin, TX
    I’m not sure what to make of that either, but the possible alternative is that there’s some sort of goop in the plug...?
  3. Gokhan
    Gokhan Senior Member
    4,619
    1,857
    Paramount CA
    Excess grease they used at the commercial charging station? Probably not. Is it hard plastic that melted? It probably still works fine.
  4. Trollbait
    11,514
    My guess is dielectric grease.
    BillKoz likes this.
  5. mr88cet
    2,306
    1,331
    Austin, TX
    I noticed on mine that there is a whitish material at the end of those electrodes, so I can’t rule out the possibility that that melted...
  6. will the engineer
    238
    119
    LA
    2019 Prius Prime
    both or just one?
  7. Trollbait
    11,514
    If it is still goo after cooling off, it isn't melted plastic. I'd actually expect some scorching and lingering odor if this is a case of high heat from a fault.
    The grease can be used in assembling the plug. There can be excess, or it simply flows out once warmed.
  8. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Get yourself a Q-tip and report back...
    Rob43
    jerrymildred, noonm and jb in NE like this.
  9. will the engineer
    238
    119
    LA
    2019 Prius Prime
    its plastic!
    when I pulled the plug out, it gave that plastic scent
    I would appreciate if anyone can look at their charging port to see if they have 1 or 2 plastic
  10. Gokhan
    4,619
    1,857
    Paramount CA
    It looks like filler material for the pins so that they don't bend or get crushed. There is nothing to worry here.
  11. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Traces of melted plastic on a multi-ampere pin? Yeah, sure, nothing to worry about...
