What are some reasons for this check engine light?
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jul 7, 2021.
  1. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    My prius only has like 90k and check engine light came on. Any advice? What are some troubleshooting steps?
  2. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    I found the answer not sure how to delete this
  3. DutchPrius
    DutchPrius Member
    78
    46
    Leiderdorp NL
    What check engine light? It looks TPMS related... Or you have a flat tire or one of the sensors is broken.
    Best regards, Nick
    Black 2007 Prius
  4. Mendel Leisk
    38,764
    TPMS = Tire Pressure Monitor System.
    Either one or more tires are low pressure, or the battery is failing on of the sensors. The sensors are in the tires, at the inside end of the tire valve. The batteries are not easily replaceable. The sensors can be replaced, and the system re-calibrated, typically by dealership, though I think tire shops may handle it too. It's not cheap though.
    Check your tire pressures, make sure they're all slightly above your usual setting, see if the light goes out. If it doesn't, you can look into replacement, or just live with it.
    #4 Mendel Leisk, Jul 7, 2021
  5. Joe Wall
    Joe Wall Member
    213
    42
    Wisconsin
    It was tire pressures. How do I prevent my catalytic converter from being stolen? Heard someone at work got theres stolen.
  6. DutchPrius
    DutchPrius Member
    78
    46
    Leiderdorp NL
    Try the "search" option
    Best regards, Nick
    Black 2007 Prius
