What are some symptoms of Spark Plugs being due for a change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Issaction, Jul 18, 2019.
  1. Issaction
    Issaction New Member
    Salt Lake City
    I have owned this car under a year and there is no history of spark plugs being changed on the CARFAX.
    It seems to run well, and I am getting 45MPG pretty consistently. My battery is original and I am at 150,000 miles.
    For all I know they were swapped at 120k miles and I don’t need to worry about it. What are some noticeable symptoms of them needing changed?
  2. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    o_O
    Ed Beaty and bisco like this.
  3. ChapmanF
    17,349
    One approach to the question could be, if it is running well now, don't obsess over them; if it later develops any misfiring, consider the unknown-age plugs to be reasonable suspects.
    Another approach might be ... maybe you'd like to get leakdown measurements somewhere around this mileage, just so you will have them to compare to later ones and track how well the engine is holding up. If you do that, you'll be taking the plugs out anyway, and with the wrenching involved, it's just as easy to put new ones in.
    51,155
    plug your vin into the toyota owners site and see if it shows any maintenance records.
    without that knowledge, when i used to buy used cars, i would do all the required maintenance for the mileage.
    for plugs, i would at the very least pull them for an inspection. it's good to keep the threads exercised
  5. qdllc
    qdllc Senior Member
    1,371
    399
    Plugs can last a crazy long time now as they are self cleaning. If they are hard to get to, you often can let it go until you have good reason to access them.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Or if you're mechanically inclined, spend $30 bucks and replace them when you're bored one weekend. Throw in an air filter, cabin filter and maybe even an oil change and transaxle fluid change. Then you'll know. A buck 25 or so and you'll have complete peace of mind that the car is good to go for quite a while.......
    gboss likes this.
  7. bisco
    51,155
    don't forget your egr circuit!
    gboss and MartenK like this.
