What are the best Affordable 12V battery options?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Banksy, Mar 11, 2020.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I'm fairly certain I'm going to need a 12V battery.
    Mine is pretty much toast.
    I'm pretty sure it was weak to start with and I'd been leaving they key inside the car which apparently is a current drain. Having left it inside the car for well over a month I'm thinking this is what killed it.
    Anyways that's off topic.
    What would be some good recommendations for a 12V replacement?
    All the ones I'm seeing are like 200 and over
    Are there any good cheap options that don't require any modifications to work properly?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Search is your friend, as there have been at least two (2) threads in the last week.
    Which auto parts stores do you have nearby?
    Raytheeagle likes this.
  3. Banksy
    415
    132
    AutoZone
    Napa
    Advance Auto parts
    49,482
    Tractor supply
  5. Banksy
    415
    132
    They have these at tractor supply?
  6. bisco
    49,482
    cheap tractor batteries (sorry, most affordable)
  7. Banksy
    415
    132
    Is there a particular model that'll work the best or is ready to go out of the box?
  8. bisco
    49,482
    Not that I know of, but there are lots of threads here on different kinds.
    I went with the oem for $200. For safety and simplicity
  9. Mendel Leisk
    38,721
    Look into electronic load testers, Solar BA9 is one.
