What are the best displays to have in OBD fusion?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Unresolved_ERR, Oct 30, 2020.
  1. Unresolved_ERR
    Unresolved_ERR Junior Member
    40
    Oklahoma
    Hello all,
    I am a new(ish) Prius owner that has done quite a bit of reading on here and elsewhere, and some posting here.
    I decided to get the OBD fusion app with the Veepeak OBDCheck BLE Bluetooth 4.0 adapter, and I was wondering if you all could answer a couple questions for me.
    1), what would the be the best displays to have on it while driving? Top 6, preferably.
    2), is it more accurate to MPG than the Prius's readout?
    3), it cannot detect certain things, such as the hybrid battery charge state (which I presume to be the amount it is being charged, such as when braking), or the fuel remaining / distance to empty. Is there any reason for this / any way to troubleshoot it?
    Thanks in advance for your response.
  2. PriusCamper
    PriusCamper Senior Member
    12,304
    4,999
    Pacific Northwest, USA
    As you know, this app you want to use is not designed for hybrid systems so it has very limited use for engine problems only. Using Dr. Prius app will work much better for you than that Apple app...
    Unresolved_ERR and Grit like this.
