What are the chances?
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Apr 16, 2024.
  1. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    That these are real NGK plugs?
    NGK LKAR7BIX-11S Iridium IX Spark Plug (93501 Iridium Ix), 4 Pack https://a.co/d/d22J3SG
  2. JC91006
    16,482
    8,400
    I don't know if they are real but I have a set at home. So many different vendors selling it on Amazon too
  3. douglasjre
    1,877
    653
    Orlando, FL
    Read reviews and found they last 30k mi bc etrode is cheap not like laser cut OEM stuff
  4. JC91006
    16,482
    8,400
    I remembered 10 years ago I bought a set of Denso/NGK branded plugs, they were iridium but only rated for 60k miles, not like the OEM stuff that was rated for 120k miles. I'm still using those 60k miles plugs, no issues.
  5. Tombukt2
    Tombukt2 Senior Member
    9,135
    1,586
    Durham NC
    With Denso plugs you need to be up on your P's and Q's and find wire terminology The ZU fine wire plugs can be platinum iridium but the fine wires made for racing and they don't last nearly as long as the long life p series or PQ series original plugs those designations of all changed over the years on purpose so it makes it even more difficult to keep up with all of the things if you can grab a copy of a nipendenzo catalog You can see all this stuff call that You generally don't want the ultra fine wire You want the long running long life what used to be called PQ series plugs back in those days those things cost $17 a pop and could be $24 x 4. I'm sure NGK has a similar lettering and similar system for fine wire racing versus long life iridium.
