What are the engine compatibility for a 2011 could I use a 2016 or have to use 2010 to 15
Discussion in 'Gen 3 Prius Technical Discussion' started by Brandon Chivari, Aug 8, 2019.
  1. Brandon Chivari
    Brandon Chivari New Member
    Pa
    I have a 2011 I bought for cheap and want to put a engine in it but I'm confused in if I can go with a newer engine I don't mind modify stuff but don't want to swap the head or stuff like that I can't find anywhere that has a chart with the Prius compatibility of what year engine you can use in what gen
    Pluggo likes this.
  2. Brandon Chivari
    Pa
    Also the engine runs but spun a bearing at 2160000 so not well and not worth repairing
  3. cnc97
    cnc97 Senior Member
    1,416
    1,525
    38
    Evansville, IN
    @Ragingfit put a 2016 engine in a Prius and a V with no engine modifications. He adapted the Prius and the V to use the Gen 4 engine as removed. There are some coolant lines to be relocated and the two coolant sensor harnesses need to be modified.
    I used the Gen 4 block with my Gen 3 head. That way I didn’t have to make those modifications. I felt it easier to put things back generally how Toyota intended.
    Ragingfit and Mendel Leisk like this.
  4. cnc97
    cnc97 Senior Member
    1,416
    1,525
    38
    Evansville, IN
    2010 to 2015 fit with no interchange issues. 2016 and newer require modifications.
    Ragingfit likes this.
  5. Mendel Leisk
    38,106
