What are the little cars on the MFD display?
Discussion in 'Newbie Forum' started by bulletprooffool, May 20, 2008.
  1. bulletprooffool
    bulletprooffool Junior Member
    37
    London, UK
    Just wondering if someone can tell me what the little cars and half cars on the fuel consumption screen mean?
    Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Each full car represents 50kWh of regenerated energy from braking/coasting.
    Note the little "car"=50kWh at the top left on the consumption screen.
  3. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Part of the way the Prius charges the traction battery is by regenerative braking, whereby the large electric motor is used as a generator, which results in the momentum of the car being used to recharge the large battery, thus slowing the car down without wasting the heat of brake pads rubbing on rotors (which does eventually happen below 7 MPH or so).
    Each car you see on the MFD shows a specific amount of electricity (50 Wh) generated in this way, so you can see how much of your charging came from regeneration. A half-car would be 25 Wh.
  4. Eve
    Eve Junior Member
    59
    S.Florida
    darn i thought it was a video game?!:fencing:
  5. bulletprooffool
    37
    London, UK
    Awesome thanks . .
    Was driving my NEW Prius for the first time yesterday . . .managed 53.4mpg over 30 miles varying Town and Motorway (It is second hand has 13000 on the clock)
    Had the screen with the little cars on . . and the 5 minute sections each had between 0.5 and 3 little cars . . so was just wondering
  6. richard schumacher
    7,664
    1,043
    United States
    Four of those cars is about enough energy to accelerate the car once from zero to 60 MPH.
    It may sound like a paradox, but for best fuel economy you want to *minimize* the number of little cars you get, that is, minimize the use of the battery. Energy conversions such as moving energy into and out of a battery always result in some energy lost as heat.
    How do you minimize use of the battery?
    - Accelerate briskly (this uses the engine most efficiently)
    - Gliding (no arrows on the energy display) is better than coasting
    - Coasting is better than braking
    - Braking is better than stopping
    - And of course, Stopping is better than hitting something :_>
  7. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    no way, 50 thousand watts/hour? that would light my house for a month
  8. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    When you buy electricity they charge you by the kilowatt-hour (kWh). When you use a 1 kilowatt appliance for 1 hour, that's a kilowatt-hour. If you used it for two hours that would be 2 kWh.
    Most things don't draw an even kilowatt, though. A typical central AC draws about 3.5 kilowatts, so in an hour it uses 3.5 kilowatt-hours. And a 100-watt light bulb uses 0.1 kW, since 1000 watts = 1 kilowatt.
  9. hill
    8,640
    Couple other trivial points:
    1) the less 'little-cars' you produce, the more efficient you are driving. Since the cars represent regen, remember its more efficient to be using that energy to the wheels rather than feeding it back into the batteries.
    2) Other models use different icons, rather than little cars. On our lexus SUV hybrid, the regen icons are little batteries.
  10. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    dude, i know this, i have an ee degree...i was being a little sarcastic to his mistake of each car being 50 thousand w/hr, what he meant was 50 w/hr's
  11. Jack66
    766
    Stafford, Virginia
    Maybe I can enlist your help on my car PC project in the near future! :D
  12. efusco
    19,891
    1,194
    Nixa, MO
    Doh! 50Wh is of course correct....
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    When I first read the legend on our consumption display, I misread it as each car being equal to 50 kw-h. I saw that and said "holy shit", then I realized my mistake. It's still better than making heat. If it was up to me, I'd display the little green cars in ergs, just to mess with people. The cgs system just doesn't get any respect.
    Tom
  14. Eve
    Eve Junior Member
    59
    S.Florida
    richard schumacher that made laugh all day...i needed that!!
    :rofl: And of course, Stopping is better than hitting something :_>
  15. Wa1hog
    Wa1hog Old Blind Hippie
    95
    South West New Hampshire
    My green car represents 5000uW/hr!!!
  16. richard schumacher
    7,664
    1,043
    United States
    Glad to be of service :_>
