What are the risks of buying a 2017 Prius with only 15,000 miles?
Discussion in 'Gen 4 Prius Main Forum' started by M123, Mar 22, 2024.
  1. M123
    M123 New Member
    New York State
    I have the opportunity to buy a neighbor's Prius. He's an older gentleman who has reached the point of no longer driving himself. His 2017 Prius 4 only has 15,000 miles, and nearly 100% of that has been in-town (not highway) driving. I regularly put 20,000+ miles per year on my 2013 Prius, so it would be quite a lifestyle change for this new one. I've searched the forums for people's thoughts on the risks of low mileage cars in terms of future battery life, etc. but haven't seen anything conclusive. I'm curious for your thoughts on this decision: would you by this 2017 Prius if it was a decent price? Are there hidden risks that need to be heavily weighed? Thanks!
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    100% I'd buy this car. I'd be prepared to swap out the 12V battery and tires possibly, if you can't determine if/when they were ever changed. That's all I've ever done, except for routine 10K oil changes, engine and cabin air filters, in our 2016 with 78K miles.
    Doug McC, Georgina Rudkus and M123 like this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,429
    Taylors, SC
    Me, too. Great find!
    My 2012 Prius v has not reached 32k miles and everything is working just fine. I've only done regular oil changes, replaced the coolant, and 12 volt battery in 12 years.
    The HV battery still charges to its full capacity. I monitor the 12volt, the ICE coolant temperature, the inverter coolant temp, and the HV battery temp with a Scangauge 2. The temps have never been above normal.
    Doug McC and M123 like this.
  4. PriAllDay
    PriAllDay Junior Member
    Central Texas
    Probably not much of a risk - just remember what Miles don't do to a car Time does - so go down the maintenance list and ensure its done - Luck and enjoy
    M123 and bisco like this.
  5. Kenny94945
    Kenny94945 Active Member
    850
    426
    Sausalito
    2016 Prius v wagon
    I'd buy.
    Risks? Where it "sat" or was stored and area weather conditions.
    FWIW
    Typically older low mile vehicles have motor and suspension rubber seal deterioration from no use.
    In this case, the car was driven about 200 miles a month... so okay to me.
    If in a snow zone with road salt usage, sitting with that salt could bring rust damage... so inspect the undercarriage.
    As mentioned above, aged out 12v battery and tires should be replaced.
    I would also change all (all) fluids (protentional moisture accumulation and age) and lube all the hinges, caliper pins, seat tracks, weatherstrips, etc. too.
    Hybrid battery, brakes, transmission, stereo, suspension.... all unknowns but I'd think all are ok with the 200 mile a month use.
    So in addition to purchase price, perhaps another $2000 (including new tires/ alignment/ balance, 12v battery/ key fob batteries, brake/coolant/trans/motor fluid changes at a shop) to recondition.
    Good luck with your decision.
    M123 and Doug McC like this.
  6. M123
    M123 New Member
    New York State
    Thanks -- it lives in southern Virginia and was garaged, so thankfully well protected from the snow/salt zone.
    Georgina Rudkus likes this.
  7. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    I don’t see any risks, as long as you follow the advice already given. I’m sure there will be some who will claim the hybrid battery is not up to snuff, but that goes contrary to the Priuses around where I live. I think you have a shot at a gem. Go for it!
    Tande and M123 like this.
  8. BiomedO1
    BiomedO1 Senior Member
    3,614
    1,869
    SacTown, Ca
    Keep an eye on the exhaust gas heat exchanger. I believe the 2016 and early 2017 didn't get the redesigned one.
    M123 and Brian1954 like this.
  9. M123
    M123 New Member
    New York State
    Hi everyone! I just wanted to say thanks -- I've owned the car for 6 months now, put over 10,000 miles on it, and it's been great! Thanks for all your help and vote of confidence on this purchase!
    Mendel Leisk, bisco and BiomedO1 like this.
  10. bisco
    51,933
    congrats!
    does it have the lithium or nimh battery?
    all the best
