What are the signs that a head gasket is going?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Higgins909, Dec 30, 2019.
  1. Higgins909
    Higgins909 Member
    277
    67
    I just passed 177,777 miles, in the past few days. (2010 Prius III) I've been told here that it's common to blow a head gasket around 190-200k miles or something like that. I'm just wondering what are the signs to look for, so I can know when to start preparing for a new vehicle or possibly repairing. All I really know is that it's been burning oil since I've gotten it. I just don't really know how much... As well as some other unsolved/partially solved noises.
    Thanks,
    Higgins909
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Engine knocking followed with coolant loss
  3. Mendel Leisk
    40,584
    Have you cleaned the EGR and intake manifold? It's a sand pounder, to just sit around waiting for the "inevitable", when some preventative maintenance would likely prevent the head gasket failure. 100K miles is not too soon.
    More head gasket failure symptoms for 3rd gen Prius:
    1. Check Engine Light with code for misfire, in particular on cylinders 1, 2, or both. (p0300 is general/random, then p0301, P0302 and so on for individual cylinders)
    2. Evidence of carbon monoxide in the coolant. (there's a test kit for that)
    If you google, there's something like 6~8 ways a head gasket can fail. There's various passages in the head gasket: the combustion chambers, oil passages, coolant passages. The head gasket can fail in ways that allow any of those 3 to leak into another, and/or to the outside.
    #3 Mendel Leisk, Dec 30, 2019
    Tande, Pluggo, KennyGS and 1 other person like this.
  4. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    Typically....a loss of coolant. Monitor the coolant reservoir level.
    Misfire...uneven idle.
    Engine oil....a milky color on the dip stick.
    Next level, perhaps an engine error code will be displayed, borescope piston top - clean piston head is a sign, sparkplug reading may or may not be a lead, compression and/or leak down test can also be an test for head gasket leak - but can also include valve sealing issues.
    Not sure your engine oil burning is a head gasket failure sign, IMO typically it is a coolant loss.
    Good luck.
