What are the specs for HV under-module bolts, and bus nuts?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Mar 19, 2022.
  1. MrPete
    MrPete Active Member
    477
    187
    Colorado, USA
    I have one bolt that popped its head off (in a bad module), and one bus nut that managed to get mangled.
    Has anyone worked out the size/thread specs on these?
    I don't relish purchasing an entire set for just one or two of each...
    THANKS!
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I updated this a bit after I reread your post. I had thought you had two damaged fasteners at the bottom of the module.
    Thread and torque is the same for the module stud and the underside fastener.
    48 inch pounds. If you have one that has a snapped head, I wouldn't even be concerned about it. Now that I relize it was snapped off in a bad module and your concern is finding a new one to install in a replacement module, the faster is M5 x 0.8, has an integral flat washer and is about 8mm long under the head.
    Gen 1 modules had those mounting screws on each end of the module. Gen 2 started using them only on one side and it's stayed that way. Considering how the modules interlock with each other, a missing fastener would be no biggie.
    The module studs are also M5 0.8 thread. Replacements are cheap at MSC dot com.
    #2 TMR-JWAP, Mar 19, 2022
    MrPete likes this.
  3. Mendel Leisk
    40,586
    Spmr torque info in attached.
    CR94 likes this.
  4. MrPete
    477
    187
    Colorado, USA
    TMR-JWRAP, perfect.
    Yes, having one missing underneath is not a big deal... Although to get everything aligned, I like to be able to get them all in. Somehow seems easier that way.
  5. MrPete
    477
    187
    Colorado, USA
    Huh. M5 x 0.8 x 10mm hex bolts are cheap at local Home Depot etc
  6. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Don't go too long on these fasteners. The last thing you want is to bottom out and risk cracking the plastic surrounding the metal insert. Cracked plastic will = P0AA6 fault if electrolyte seeps into a crack and makes contact with that insert. If you need OEM, just message your mailing info to me at the number that shows up if you click on my user name. I have hundreds and would be happy to send you some.
  7. MrPete
    477
    187
    Colorado, USA
    Thanx... Yeah, would never want to crack one.
    I appreciate the offer!
  8. MrPete
    477
    187
    Colorado, USA
    Update with more info:
    The mounting holes underneath are 14mm deep. 10mm bolt is fine.
    I managed to round off one of the nuts for the power studs.
    Nothing: wd40, heat, vise grips... Would loosen it. I'm about to dismantle with a dremel tool.
    I bought some 5mmx0.8 nuts and washers down the hill at Lowe's but am concerned that's a very temp fix:
    Thinking about it with my EE hat on, every module battery nut must handle transferring over 100 Amps between stud and copper plate. That's *why* the nut with integrated thick washer.
    @TMR-JWAP if you have spare module nuts, I could use a few
  9. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Just text your mailing info to the number listed under my user name and I'll have some on the way tomorrow.
  10. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Padded envelope with 5 terminal nuts and 2 busbars dropped off at USPS 6am this morning. That way you have spares if needed.
    MrPete likes this.
  11. SB6
    SB6 Member
    324
    71
    I ran into this thread while looking for the battery balde nut size, as I'm replacing my voltage sensor and sense wires, and found a damaged nut. I see M5 x 0.8 already mentioned, but what material am I looking for in a replacement?
  12. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    The M5x0.8 flange nut can be purchased from McMaster-Carr in stainless steel. 50 pieces per bag for less than $12.
    Item # 93033A106 $11.43 for a pack of 50
    #12 TMR-JWAP, Jan 15, 2023
  13. SB6
    SB6 Member
    324
    71
    In order to get this done ASAP, I ended up ordering these from Amazon, as it was showing to be the quickest delivery. I'm hoping the quality doesn't turn out to be terrible.
    Code:
    https://www.amazon.com/dp/B08TM4DJ6P
    Any thoughts?
  14. Mendel Leisk
    40,586
    Same link as above
    They’ve got nylon lock sleaves. Don’t think it’d matter though.
    #14 Mendel Leisk, Jan 16, 2023
  15. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Just make sure you torque all the M5 nuts and screws to 48 INCH-pounds.
    Not a fan of nylocks but they should stay in place as long as they're torqued correctly.
    It hurt my brain trying to read the description. Reminds me of the chinese-english instructions provided back in the 70s and 80s.
  16. SB6
    SB6 Member
    324
    71
    Anything I can test myself to check their quality? I installed a couple, torqued to 48 inch-pounds, and measured 0 ohms between each nut and its respective stud. I mean I didn't expect any different, but that was the only test I could think of.
  17. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    If they torqued down correctly without stripping the threads then you should be good to go. The important thing is that the busbar is cleanly compressed between the fastener and the base of the module terminal stud.
    MrPete likes this.
