What are the symptoms of the battery dying?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KarunaS, Sep 2, 2010.
  1. KarunaS
    KarunaS New Member
    Maui
    I have a 2004 Prius with about 50K miles. It is driven every day.
    I recently noticed that the motor doesn't shut off as frequently as it used to when I stop at a light. It then also shows the battery as almost empty (1 bar) on the touch screen. Gas mileage also seems to be a little lower than it used to be. Other than that the car drives fine.
    Could this be an indication of the battery starting to go?
    Thanks,
    Chris
    ETP likes this.
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I'd look into replacing the 12v battery first.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Chris,
    the conditions you noted are classic symptoms of the 12V battery needing
    replacement.
    If you're still on the OEM battery, they have typical service life of 4 years...
    and you've gone six. :thumb:
    Time to pay the piper. ;)
    dstahre likes this.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Your Prius has (at least) 3 batteries, with different symptoms.
    The Fob Battery runs the doors and ignition functions If the door don't open or the car needs the key inserted to start, suspect the fob battery.
    The 12v battery runs accessories when not READY, and powers the computers so you can start the car, as it runs down the HV Battery may spend a great deal of effort recharging it, leading to poor gas mileage, and the computer may become more and more confused, forgetting presets. Also when not READY, it may have difficulty with the power windows.
    The HV battery has computers watching after it's every need. if it is not doing well, the instrument panel lights up like a christmas tree.
  6. KarunaS
    KarunaS New Member
    Maui
    Thanks to everybody who responded. I am relieved to hear that it's probably not the hybrid battery. Will do the battery test procedure tomorrow.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    And let us know your findings.
  8. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    I tried the battery test on my 08 but the display screen is different and doesn't allow me to hit the display icon, opening up the next series. is there another test?
    mine is a #6, 2008
  9. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
  10. 2009Prius
    2,705
    511
    63
    Yes the graphics is for older models (04-05?) but the same procedure worked fine on my 09. Not clear which step you are having problem. Note in the instruction the "display switch" refers to the actual button labeled "display" on the side of the MFD, not the "display" word on the screen. If you still have problem please clarify exactly which step you can't do. There is always another alternative to invest in a digital multimeter which has become very affordable and is generally very useful. Good luck!
  11. Bob64
    1,540
    93
    Virginia
    I'd like to note that the symptoms of the HV battery dying are as following:
    VERY RAPID changes in state of charge. (green to purple in less then 3 minutes) or
    You park the car with blue bars and turn it off, then next morning, it has 1 red bar.
    You hear the battery cooling fan on all the time.
  12. KarunaS
    KarunaS New Member
    Maui
    That was exciting! I did the battery test and 12V voltage display shows as 11.9V.
    If I turn on the headlights, it drops to 11.5V
    So....does this mean, the battery is borderline :confused::confused:
    BTW, Prius was behaving well today with motor shutting off at every stop light.
    Aloha, Karuna
  13. Patrick Wong
    18,200
    6,493
    The voltage readings imply the battery is borderline. However keep in mind that error potentially exists in the readout, possibly as much as +/- 0.7V.
    Nevertheless, since your 12V battery is six years old I recommend that you replace it now. This may or may not address the symptoms that you described in your OP. Regardless, installation of a new battery will reduce the likelihood that you'll experience a no-start situation in the near future.
  14. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yep that battery sounds like it's close to end of life. I'd replace it soon.
    Re your state of charge (SOC) dropping to one bar and the engine staying on (it will do that when the SOC is low). Can you think of any driving conditions that might have caused that low SOC. The one that most often effects me is if I start driving up hill from a cold start. I find that can run down the battery a fair bit in the first few minutes and then depending on where and how I'm driving it can take a while to get the SOC levels right back up there.
    Anyway, do make sure you let us all know how it turns out after you get a new 12V battery.
  15. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    4 years later. .. I have a 2005 with 232,900 miles. On my commute to work it always seems to stay at 6 bars SOC except one place where it goes to green at 7 bars.
    Well this morning it randomly dropped to 5 bars, 5 minutes in to the drive.
    Thought it was due to having rear defrost on. . Maybe? But then where it goes to 6 7 bars (due to braking down a hill at 6 mph) it went completely full!
    And then while driving along after that 2 mins later @ a steady 55 it drains to 5 bars?? It has never done that and I drive this road 5 times a week.
    Battery voltage after a long drive 12.2 volts no load. It's a optima battery and I have no clue how old it is
  16. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    And just got my grid charger in the mail yesterday.. I'm almost afraid to use it now! What do I do? I hope the battery isn't dieing!
    I also don't hear the fan running
  17. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    As long as it hasn’t thrown trouble code using charger to SLOWLY overcharge it may repair it for long time. If fan doesn’t that is first thing to repair. Check battery temperature and/or use something to command fan on.
  18. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Well today on the way home from work it never acted odd or fluctuated. Started grid charging it today
    jeff652 and Prius_Cub like this.
  19. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Same as a dying cat. Won't get up and run, walks slow, makes a lot of noise, something stopped up.
  20. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    my 2007 HV batt died @ 128000 mi. 2 cells were bad - it does the same thing a laptop battery does. You will get a couple of codes - can't remember what they were but it is a stretch to assoc them with the HV batt. A Techstream will show exactly which cells are bad.The dealer did that for me. The 12v batt went bad at the same time - about 6-7 yrs. They are rather pricey also. The HV batt is about $3000. at a dealer but there are options if you are handy or not - even just replacing the bad cells.
    Briana Giselle Jauregui and ETP like this.
