What are the things i should do if i didn't start engine for around 6 months?
Discussion in 'Gen 3 Prius Main Forum' started by tolick, May 26, 2011.
  1. tolick
    tolick Junior Member
    32
    Chisinau, Moldova(Europe)
    Hello! I bought a 2010 Prius IV from USA. I'm from Moldova(europe). So when i bought it, the engine wasn't turned on for around 3 months, then during transportation to Moldova from USA(around 3 months) it wasn't started also? So, next week i should already have the car here in Moldova and want to know if there are special maintenance i need to do before starting the car. I mean for electric engine(system) because i know there is no problem for a gas engine if it will not be started for some months or years, but what about electric system from the Prius? Please share your opinion but don't send me to local dealer because in Moldova things are not like in USA. Tell me if there is something i should do before starting my car engine when i'll receive it. Do you think i'll have problems with hybrid system if the car engine wasn't started for around 6 months? Hope you'll be able to help me and your replies.
  2. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    The battery might be dead...you'll know when you attempt to power it on. ;-)
  3. tolick
    32
    about this i know, this is not a problem i think, it will be charged and then it will be fine. but what about hybrid system???
  4. vinnie97
    1,430
    277
    Somewhere out there
    Nothing I can think of...but I'll let some more experienced Hybrid drivers/tinkerers answer that definitively.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I am not sure about the HV battery being flat after 6 months - it might well be. But if the 12v is flat you must be very careful how you jump start the car! You are probably best taking the 12v off the car and charging it that way or maybe even replacing it if it has been allowed to fully discharge - they're not that expensive.
    If the 12v is OK and the HV battery is flat (they do slowly lose charge over time without use) then I think you need special equipment to charge it back if the car is unable to do it.
  6. vinnie97
    1,430
    277
    Somewhere out there
    I was referring to the 12v battery, yes. Trickle-charging that battery (if the vehicle doesn't start) surely shouldn't cause anything untoward to happen.
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    if the 12v sat for 6 months i would just buy a new one. the HV battery should be fine.
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Unless the car was shut down with a very low HV battery (unlikely) then it is fine. the self discarge rate is something like 2% a month. If the car was shut down with 2 bars on the battery, it had about 45% charge. 9 months later it would have ~27% charge. This is low enough that the car will be angry, and will want to spend a while charging when started up (and will take a while to get to six bars), but it will certainly run.
    If it went into storage with 6 bars on screen it had about 65% charge, and now has about 47%. that is completely within the entirely normal range and the car will operate normally immediately.
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    If the car really sat unused for 6 months, I would change oil and filter. Also, I would check tire air pressure. As far as the rest of the car, I think it should be fine. I think the hybrid batteries would be okay. The gasoline might need to be replaced if it's been in the tank for 6 months.
    You might drive the car as if it were brand new; easy accelerations, no excessive high speeds for long periods. Maybe a new car break-in for a couple thousand miles.
  10. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    And use 0w20 oil in a gen3/2010 Prius :)
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Check fluid levels, engine oil, coolant (two systems), and brake fluid. Check tire pressures and fill washer bottle.
    Put in some gas (gas may have been drained prior to shipping) and try to start it. 12V battery will probably be dead so you can either jump it or put a charger on it for a while.
    Go for a long drive.
    After it is completely warmed up and has run for a while I would suggest changing oil and filter. If it has over 20K miles you should consider changing transaxle fluid also. As previously mentioned most of us use 0W20 engine oil but if you can't find it 5W20 or 5W30 should be fine; transaxle must have Toyota ATF type WS (no substitutes).
  12. tolick
    32
    This is a so great forum. I received answer to all of my questions. Thank you very much to everyone! I already have oil/air/cabin filter bought from parts.com and they are waiting for my car. Also a new 12v battery is here. The tire pump also is waiting, just the car should arrive :)
  13. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    If they did it right ALL fluids will be drained. I recently had to send a piece of rebar processing equipment to Colombia and it had to be dry.
    So check ALL fluids: coolant, brake, steering, transaxle, oil, washer etc... before driving. Car companies might have waivers for this but individuals might not...best to be safe and check.
  14. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    if battery is charged the rest should be fine.. just disconnect charger before start..
    On old cars which were sitting for much longer you have to worry about bore rust/old gas/carb cleaning.. but 6mo only plus EFI shouldn't be issue.
    If you planning to store car for prolong time adding gas stabilizer and putting battery on trickle is all you need..
  15. Mendel Leisk
    40,586
    Go very easy on the brakes for the first drive too: the disks will likely have built up rust.
