What are these filthy plastic things?
Discussion in 'Gen 3 Prius Main Forum' started by b100, Jul 12, 2017.
  1. b100
    b100 Member
    145
    75
    Netherlands
    Hello folks,
    I was wondering, what are these plastic "covers" for.
    First i thought that they where stickers, but after a closer look they look like covers. I mean they are thicker than a sticker. And some filthy stuff if around the corners.
    52,385
    just protection, i think.
    Data Daedalus and Raytheeagle like this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    Bisco is probably right. A more fitting description would be "Child Proofing". Run-a-way seat belt buckles, back pack dragging across the door edge, opening doors into curbs are among some of the scenarios I can envision. In any event they are probably the to protect the paint from these kinds of mishaps.
    Data Daedalus likes this.
  4. Mendel Leisk
    41,896
    The one on the door in particular seems kinda pointless: doesn't cover the edge.
    We had bodywork in that zone, and they dutifully replaced those after painting: they have part numbers and all.
    Are the edges lifting, dirts getting under? In that case I'd just pull them off and apply some polish.
    If the dirts just at the edge, it's probably from too many automatic car wash, not enough hand washing, with attention to detail? If the latter I'd just run around the edge with a toothpick or similar.
  5. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    These threads always cause me to jump up, and run out to check my car. :) :) My 2016 only has the long one. Door frame edge protection, as mentioned by bisco. Mine aren't dirty yet, but maybe a soft toothbrush would work to clean it?
    (As my Prius BAKES... I got blasted by heat when I opened the door! No garage. No shade. I can put my morning coffee in there, and it will stay hot all day! :))
  6. Mendel Leisk
    41,896
    Try to park aimed away from the sun (or is it directly overhead in your neck of the woods...), a few years parking in sun will frost the "resin" (plastic) headlights.
  7. Tideland Prius
    16,615
    I don't know but all Gen 3s have it (and most cars have some sort of clear plastic thing around the lower rear door as yours does). I just assume it's for rock chip protection.
  8. b100
    b100 Member
    145
    75
    Netherlands
    Thanks for the explain. Maybe i order new ones. This ones look terrible on my perfect white car:)
  9. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    Peel them off and polish up the spot where they are. You will never miss them.
    Data Daedalus and Mendel Leisk like this.
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The dirt is only accumulating on the edges. You can clean that off and they will be like new. They aren't easy to get off, and do serve a purpose. Mostly chip protection.
  11. Mendel Leisk
    41,896
    Try David's suggestion first, see how it goes. If the dirt has got in behind, go with Yippeekyaa's suggestion.
  12. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    always tough in a white car. I have similar issues with my white honda cr-v. i won't go white again for exterior.
  13. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Car aerodynamics blasts dust particles in those areas. Without that transparent plastic, the metal would get bombarded and rust more quickly
    I have a friend with a Ford and for unknown reasons he is missing that protection. Now he has quite some rust there!
  14. stephensprius
    670
    226
    that makes sense.
  15. harrysprius
    harrysprius Active Member
    277
    126
    Nashville, TN
    I think white and grey hide the dirt the best! I have a black car and suv, and a white prius. The prius seems to stay cleaner looking the longest and it gets driven the most. Maybe the aerodynamics help the dirt to "flow" away?
    On another note, you can seriously tell the difference in how hot they get. There is no comparison, the black ones get hotter much faster.
  16. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Like front car bras, these protection appliques don't make any sense to me including the one on the rear bumper. They certainly do their job but they are. 1. When new, you can see them and they disrupt the smooth lines of the car. 2. After time, they look like yours and traps even more dirt. If you live in a place where rust is a problem, then I guess they're needed? Where I live rock chips and dents are less noticeable than a dirty sticker.
    P.S. My wife bought rubber floor mats to protect the carpeted floor mats that protect the carpet underneath. This makes no sense to me, either.
    Raytheeagle likes this.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Probably make as much sense as aerodynamic vent shades:p.
    mmmodem likes this.
  18. mmmodem
    2,732
    1,703
    Bay Area, CA
    I knew you would see this post!:cool:
  19. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    At least you are consistent (y).
  20. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Try bug and tar remover around the edges.
