what are these marks on my car?
Discussion in 'Prime Main Forum (2017-2022)' started by Tomca, Sep 3, 2019.
  1. Tomca
    Tomca Junior Member
    48
    CA
    I got a 1 yr old prius prime. I have set it for about 2 weeks during the summer. And today I went to a express car wash. After it dried up, I went to Costco. After I come back and load up my stuff, I saw these strange white/transparent marks on my car. What are these? Are these caused by car wash? I am not sure if they were there before car wash or not. I did not pay much attention.
    If anyone knows, how do I get rid of it? I never saw something like this before.
    Edit: so from what people said here, it seems to be some damage on clear coat. Could some one with experience suggest me some product for rubbing it off? Polishing? Rubbing? Any brand or sepecific product?
    I marked the rea with red circles, Hope you could see it. It's like some tire or shoe marks.
    #1 Tomca, Sep 3, 2019
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It looks like the spray wax wasn't evenly applied. If it is extra material and rubs off when you apply pressure, then it's most likely wax. If it is the opposite and is actually cut into the clear coat, then something hit you.
    Trollbait, Tomca and Mendel Leisk like this.
  3. Mendel Leisk
    41,879
    Try going over it with some polish.
    Tomca likes this.
  4. Tomca
    Tomca Junior Member
    48
    CA
    I never waxed my car. I am very careful driver. Unless something hit my parked car, I don't remember been hit. I am just wondering if it could be caused by car wash?
    Another question? anyone know how to get rid of it? Rubbing compound + polish?
    BTW, could I ask a newbie question: when do I need to use rubbing compound in addition to polish?
    If possible, I should be using less rubbing compound as possible since it will eat away some clear coating?
    #4 Tomca, Sep 3, 2019
  5. Mendel Leisk
    41,879
    The car wash might have applied something.
    Start with regular polish. If they're still there I'd moisten a cloth with kerosene, add a dab of polish, try some more. I found that worked good for tree sap.
    Save rubbing compound for last, it might just "compound" the problem... (groaner)
    Tomca likes this.
  6. Tomca
    Tomca Junior Member
    48
    CA
    For using kerosene, do I need to wash the car after applying it? I ordered some polishing pads from Meguiar's
    Do you have any suggestion on which brand to use? Thanks.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Automated car washes apply waxing compounds. So yes you got it waxed. And that improper spray is usual with spray on (i.e. automatic carwash applications) waxes.
  8. Tomca
    Tomca Junior Member
    48
    CA
    So it is caused by car wash then. Do I go back to their place and ask them to fix it? Would they do that?
    I tried to scratch it off with a microfiber cloth with hard pressure. It does not help.
    Nvm, I just checked their website. And package I chose does not include was. Just soap foam, rinse and blow dry.
    I guess I will just try to polish them off first. Thanks for everyone. I don't know what caused this. Hope it will go off.
  9. Mendel Leisk
    41,879
    I wonder, would they wax every car that goes through, regardless of your paying for it or not? They just try to sell you on it upfront? Or they just screwed up on the settings.
  10. Tomca
    Tomca Junior Member
    48
    CA
    No idea, they have 4 packages. I guess they configure the setting before you went thru.
    They have 2 workers to pre-wash your car at the entrace, then you go in.
  11. Washingtonian
    Washingtonian Senior Member
    726
    621
    If it were my car I would go back to the car wash first thing in the morning and ask to speak to the manager. He or she will know if it is something they did and will know how to make it right. If it has happened to your car, it will have happened to others as well. Incidentally, rubbing compound is an abrasive cleaner. It would be used, for example if another car had rubbed against yours and left some of their paint there. Think of it as a very fine sandpaper that can the shine from your paint.
    Tomca likes this.
  12. Tomca
    Tomca Junior Member
    48
    CA
    Thank you for your info. So would you recommand to use rubbing compound in fixing something like this? Do you have any product suggestion? I am trying to buy something to fix it, but you know all these "fake" reviews are everywhere. Don't know what to believe.
  13. Mendel Leisk
    41,879
    I'm not sure, but don't think he's recommending rubbing compound as a solution. Perhaps read too quickly, was thinking RB was cause of your problem??
    Anyway, I would definitely NOT start with rubbing compound, it's quite abrasive. And it's a good idea, the recommendation to talk with the car wash manager.
  14. JC91006
    16,827
    8,600
    Have you tried just basic car wax? It should come right off
  15. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Well I’d do what @“Mendel Leisk” suggested or try rubbing alcohol and/or ammonia. Make sure that side is shaded and have a hose or spray bottle of water handy to wipe after applying. From your pictures, looks like soap and/or wax residue that never dissolved. Rubbing or polishing compound would be used as a last resort, and of the two I’d rather use jewelry polishing compound. After rinsing, use a good cleaner wax to get the remaining stuff you can’t see.
    Edit: I use denatured alcohol to clean just about anything on a painted surface. You can get a small container at any home improvement or paint store/department. Rubbing alcohol is a more diluted version of denatured alcohol but use gloves and eye protection for any of those suggestions.
    iPad ? Pro
    #15 drash, Sep 4, 2019
    Raytheeagle likes this.
  16. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    Hang on did anyone try a wet rag yet? Looks like it could just be hard water spotting.
    Mendel Leisk and JC91006 like this.
  17. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    EV en with physical access to the car, often it's hard to tell exactly what problem is showing up in the paint.
    I'm still trying to figure out what kind of paint/clear system Toyota uses, (urethane? / other?) because the different types don't always play nice together. I'm not a professional Auto Body Painter! and my prices reflect that in a major way LOL....
    To me. (( looking at the pics, )) it looks like it could be mild abrasion to the clear coat.Since it looks like it's not into the base color at all yet.
    I notice Tomca mentioned polishing compound and responses noted not using rubbing compound. I agree Mendal, I wouldn't use polishing compound or rubbing compound on them. at least not before trying less abrasive methods to try to determine what the marks actually are.
    I notice (skimming quickly through the posts) that Tomca mentions using denatured alcohol for many paint related issues. I also use Mineral Spirits with most painted surfaces, not on all types of paint though. Turpentine is a bit harsher then either alcohol or mineral spirits, yet from my experience (doesn't) seen to harm the clear coat much if at all. On the other hand liberal use of lacquer thinner usually eats away at most clears and/or base colors without showing up while applying it, until after it too late. making the issue worse.
    I'd recommend NOT trying to get rid of all the marks but Rather work on a small part of the mark(s) that are the least noticeable when looking at the car from all directions. At least until it's determined with reasonable certainty what the marks actually are and what to use to fix them. Than when you know what works best use that method to repair all of the marks.
    Sorry, no concrete suggestions about what to use from looking at the pics. I'm not sure I would be able to determine what the marks actually are even if I was looking at them in person, until I tried a few of the methods already mentioned above by both Tomca and other members suggestions...
    There are paint tricks that can be used if the marks are abrasions in the clear coat. I'd recommend being careful trying to remove the marks
    if that is what the problem is, because you will only remove more clear from the area with the problem without helping the appearance of the problem area.
    Once it's determined what type of paint and clear Toyota uses the easiest way to fix issues with the clar coat is to polish the area, clean it thoroughly with prep-sol and shoot it with a few coats of clearcoat of a OEM matching type clear, but that is not the method I'd suggest using without more knowledge of the problem, and, the solution to the problem to use for the best results.
    #17 vvillovv, Sep 4, 2019
  18. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And there is NO WAY I would waste my time and energy doing that.......since he has absolutely NO proof that they caused the marks.
    Get some white (light duty) rubbing compound, clean off the marks and then apply some polish.
    Gotta say, though, that those marks look a LOT like the ones I got when I "rubbed" a plastic wrapped concrete pole with my C. The clear coat tends to turn white when it is scraped.
    I even got a very slight dent too.
  19. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    "Rubbing compound?"
    Rubbing compound comes in different levels of abrasiveness. The red rubbing compound is very abrasive and requires a knowledgeable touch. White polishing compound is less abrasive, but still has a potential for damage if used too hard or too much.
    Try just a dry clean soft cotton cloth, old tee shirt or towel. If that won't rub it off, then try a polish labeled for removal of fine scratches. A light touch is a good touch. Less is more. It's better to leave some of the scratching than to rub too much and wear through part of the paint.
  20. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    I like ScratchX 2.0 for light scratches to the clearcoat. It has strong solvents that get a lot of stuff off by itself. And I think it has diminishing abrasive so it doesn't leave more scratches if used correctly.
    I'd definitely be very careful with random rubbing or polishing compound, because you could easily make things worse. Even with ScratchX you should be careful. I've never had a problem with it, but I'm also not too picky about my paint.
