What are these two cables? Help me not melt my Prius!
Discussion in 'Gen 3 Prius Audio and Electronics' started by sinfony, Sep 24, 2019.
  1. sinfony
    sinfony New Member
    Palo Alto, CA
    Hello! I'm planning to swap out the factory Nav system (no JBL) in my 2014 Prius 3 with a Pioneer unit. However, after poring over the wiring diagrams I've found, I'm not quite sure what the two plugs at the far right of this picture are:
    To be clear, I'm referring to the blue plug with a gray cable seen in the top right corner of this image, and the white plug directly beneath it that has two black cables running into a sleeve (I believe there's also a third cable tucked in there that you can't see in this picture). Anybody know what these cables are? I'd like to not, you know, destroy the new head unit and/or the car because I didn't know what these wires do.
  2. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    The blue one is the sub antenna, the white is the FM antenna.
    Fyretuck and sinfony like this.
  3. CallmeSusan
    CallmeSusan Junior Member
    Phoenix, az
    can you tell me where you got the wiring diagrams? I am desperately searching for them
    49,490
    techinfo.toyota.com
  5. ChapmanF
    15,614
    I have found the Toyota wiring diagrams, weirdly, to be rather sparse on details for antenna connections, compared to how thoroughly they present everything else.
