What are these wires for or where should they go?
Discussion in 'Prius v Main Forum' started by ZeroM8, Oct 7, 2019.
  1. ZeroM8
    ZeroM8 Junior Member
    74
    Toronto
    2001 Prius
    IMG-20191007-WA0002.jpg IMG-20191007-WA0004.jpg Please see the pictures. I bought a used Prius V and the previous owner(s) cut these wire(s) connected to the 12V positive terminal, or were they even part of the original wiring? I have no clue but would sure like your inputs. I'd like to wire them correctly or remove them altogether.
    It's those red wires connected to the + terminal of the batter in red wires/yellow lug...
    Thanks in advance and my apologies if this is the wrong spot for this question, moderator please move if needed.
  2. JC91006
    16,674
    8,519
    No that's not original
  3. fuzzy1
    10,335
    After reviewing my 2012 Liftback, which ought to be essentially identical to a 'v' for nearly everything except rear body shape, my vote is that it was from some aftermarket addition, cut off quickly when sold. Remove that yellow-coated lug, and the rest does look just like mine.
    scona likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Probably went to an aftermarket amplifier, trickle charger or trailer towing kit. I would not worry about it.
    WilDavis and scona like this.
  5. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    That looks like someone tapped from the positive battery post to power something like an inverter, or something that
    they wanted to operate in or near the vehicle. That type of connector is not commonly used in a Prius, to the best of
    my knowledge. I would just remove it and forget that it was ever there.
  6. ZeroM8
    74
    Toronto
    2001 Prius
    Hey all, thanks so much for all your inputs, it will be duly removed as advised...
