What are these?
Discussion in 'Gen 2 Prius Main Forum' started by jcoasternut, Dec 29, 2020.
  1. jcoasternut
    jcoasternut Junior Member
    Indiana
    I just had my 2008 prius towed out of my driveway this am. I found these in the gravel afterwards. They look to have come off the underside. They are soft pliable rubber. There were tire marks where it looked like it was drug through the gravel. It was towed from the rear as car was facing forward in the driveway. Are they anything to be concerned about? They must have served some function.
    49,391
    look like plugs. maybe where they hooked up the tow cable. hang on to them if you're getting the car back.
  3. Mendel Leisk
    38,652
    I guessed before I even enlarged the picture you posted. Those go into oblong holes on a heavy gauge plate, just inboard of the rear scissor jack bearing points. Look under there and you'll see. I believe they ship-loose from the factory, since on ship or wherever there's locator pins that go into those holes, to prevent the car shifting around.
    Every so often there's a post here: someone finds that pair of plugs in their glove box (upon delivery of a new car). The dealership is supposed to install them as part of Pre-Delivery Inspection, but sometimes drop the ball.
  4. jcoasternut
    Indiana
    Thank you !!! Do you feel it is necessary to put them back or not ?
  5. ETC(SS)
    6,543
    Pends on how long you plan on keeping the car and/or how much sand, salt, etc might get into the holes....
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Definitely put them back. As @ETC(SS) said, they keep corrosive debris out of those cavities.
  7. Mendel Leisk
    38,652
    ^ What he said.
  8. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    Ditto!
  9. jcoasternut
    Indiana
    Thank you !!!!!
