What auxiliary battery should I use?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sihanat meas, Apr 18, 2017.
  1. sihanat meas
    sihanat meas New Member
    Alexandria
    Can I use this battery, EverStart Maxx Lead Acid Automotive Battery, Group Size 24F ?
    It can be bought at Walmart and cost only $93
    as a replacement for the auxiliary battery, its I like to use its since its affordable.
    My battery is has gone weak and I can't afford to spend to much, I like to know the least expensive option to buying a prius battery.
    52,366
    if it's the exact size, correct post size, correct post orientation and has the vent tube, go for it! that's the cheapest i've seen.(y)
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    No.
    For safety reasons, you need an externally vented Absorbed Glass Mat battery.
    The Prius battery has JIS Posts, if you do not use a compatible battery with JIS posts, you will have to replace your battery cables.
    The buzz word for this battery is S46B24R. Autozone, Oriellys, NAPA carry them.
    The battery sold by Toyota dealers has a 84 month warranty.
    The cheapest battery I know of the is a direct fit is amazon.com/ACDelco-ACDB24R-Advantage-Automotive-Battery/dp/B010GKJ8F6
    The Optima yellowtop has a great reputation Optima DS46B24R Optima battery direct fit replacement for Prius 2004 to 2015 , Prius V & Plug-in Prius with Instructions
    itsgood2balive likes this.
  4. sihanat meas
    Alexandria
    So your recommended batteries would work for the 2007 Prius?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes, S46B24R is the right size for 2004 to 2015 liftback and all v.
  6. bisco
    52,366
    in 2007 (gen 2) there is sks and non sks 12v battery.
  7. Currahee
    Currahee Member
    103
    34
    CT
    The battery is the same regardless of the key system.
  8. bisco
    52,366
    thanks, i must have misremembered.
  9. sihanat meas
    Alexandria
    Could this battery work?
    EverStart Plus Lead Acid Automotive Battery, Group Size 65-3
    From walmart
  10. sihanat meas
    Alexandria
    or this one
    EverStart Maxx Lead Acid Automotive Battery, Groups Size 51
  11. Currahee
    Currahee Member
    103
    34
    CT
    Wrong size and not AGM.
  12. camner
    camner Junior Member
    68
    This simply is not correct. There are MANY threads that indicate that for a Gen 2 Prius, the battery for the BASE model is smaller than for any model having the SKS (keyless entry) system.
  13. bisco
    52,366
    who was i to argue?
