What battery for a Backup Generator?
Discussion in 'Fred's House of Pancakes' started by kenmce, Oct 3, 2010.
  1. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    I have a gas/electric generator that spends most of its time sitting idle in an unheated garage. It needs a new battery. What's the best one to get? What's a good solid photo-electric battery minder to keep it topped up?
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
  3. nthach
    nthach New Member
    174
    Small generators with electric start will usually use a wheelchair/lawn tractor battery, I've seen some at the local Honda Power Equipment dealer that use the same 12V battery as the Prius - but in a "open" form.
    I think a Battery Tender can work here - but shouldn't your power transfer system also have a provision to charge the 12V battery?
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I take it that by "open,' you mean it doesnt have the vent tube. Yes?
    Also, is it really the same dimensions with the same +/- pole orientation?
    Lastly, do you know the brand and cost?
    Sorry to be such a pain in the neck.
    Inquiring minds want to know. ;)
  5. nthach
    nthach New Member
    174
    By open - it have vent caps you can take off and top off with water. The batteries are sent dry, the selling dealer fills it with electrolyte when it's delivered to the customer.
    Yuasa makes them, and apparently Kubota and a few other Japanese made tractors use them.
    It's a 46B24L or 46B24R battery.
  6. partsmore
    partsmore Junior Member
    85
    NE
    Purchase a deep cycle battery - www.batterystoreonline;
    and attach a battery brain and IF the battery does drain down
    it will disconnect at 11v preventing damage to the battery;
    and assure that the generator will always start;
    a 81708 12V 4a trickle charger / maintainer would also be a easy way to keep
    the battery full charged.
  7. jayman
    13,439
    640
    Winnipeg Manitoba
    Again, make sure whatever maintainer that is left hooked up to the battery is designed to be left hooked up 24x7. The Kussmaul unit is designed to keep a "float" charge, so is the VDC
    Also, verify that the generator 12 vdc system actually works. You'd be surprised how often they don't, so with the float charger keeping the battery topped off, it will start just fine
    Then when the power outtage is over and line power is restored, folks are surprised to get a low battery alarm on the panel.
