What Brand of Battery do you like ? (Auxiliary)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jul 14, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    What is a good quality Aux battery for a 2010
    Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    For years I've had good luck with the interstate middle of the road or the higher end AGM batteries from the same company other brands that I used to use are long gone like Deka. And of course if you're in a foreign country I don't even have the names of the batteries I used to use in Germany and Spain years ago and I'm sure it wouldn't matter anyway. You'll find some guys here running universal battery type batteries they're a lot cheaper and they should last about as long
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    These are the best price and best quality... If you decide to buy one I can explain an easy way to mount the terminals... I got 9 years out of a battery similar to this one in my Prius: https://ebay.us/5n8222
    Taxi/Limo likes this.
  4. Taxi/Limo
    524
    107
    $123.00 is that a good price?
    douglasjre likes this.
  5. PriusCamper
    12,064
    4,896
    Yes! Most auto parts stores will be up in the $300 range for a 12v with way less than 55amp-hours
  6. bisco
    51,155
    oem true start
  7. Taxi/Limo
    524
    107
    How many amp hours does a typical batt have?
    Thanks
  8. PriusCamper
    12,064
    4,896
    Most of them have around 38 amp-hours... Basically, a regular car's 12v has to start the engine, but a Prius has a high voltage battery and an electric motor inside the transmission to start the engine. So a 12v "cold cranking amps" rating is not relevant so you can instead invest in the battery most likely to keep working if you leave your headlights on, forget to close the door all the way / longest lifespan which is a mobility battery. These batteries are used in wheelchairs and back up home computer power supplies so the amount of them that are sold and the nature of the market keeps prices low.
    We've been arguing over this way of doing things on Prius chat for a decade... The main thread discussing all the different opinions is here: Fitting mobility 12volt AGM battery. | PriusChat
  9. Taxi/Limo
    524
    107
    I did not know that
  10. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I mostly agree with your post.
    A "mobility battery" is only one of many potential applications for a general-purpose AGM battery. I've been using a "U-1" sized utility AGM for nearly 7½ years with no problems. It required a little more effort to adapt, and has slightly lower ampere-hour capacity, but otherwise, as far as I can tell, has served equally as well as a dealer battery that cost 3 or 4 times as much would've. A larger "mobility battery" than mine can also be made to fit. So can a Group 51 AGM for non-hybrids, which is conveniently the same physical size as a Prius battery, but needs different terminal connections.
  11. Taxi/Limo
    524
    107
    Your U-1 did you change the terminals and where did you get it ? Thanks
  12. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I got it through Amazon from a battery specialist site in Minnesota. I later bought another one as back-up at a slightly higher price from Harbor Freight (which markets them as a component for low-power solar systems). Those batteries are available from numerous other vendors.
    No, I didn't change the terminals, but simply clamped the original cable clamps directly onto the flag terminals of the U-1. That looks clumsy, but functions well, and is easily reversible in case someday I switch back to a battery with JIS terminals like the original. I checked a few times to be certain the clamps stayed tight. There may be a better way. Fortunately, 12-v battery terminals in a Prius must carry only a small fraction of the current necessary to crank an engine. Some otherwise identical batteries have a less common terminal configuration that might be less clumsy to mate to the Prius cable clamps.
    I also added spacers above and behind the U-1 to locate it securely with the mounting original clamps, and added a vent system to direct any gas from the battery (unlikely) out through the original venting hose.
  13. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
  14. Taxi/Limo
    524
    107
    This one is cheaper than the one at the dealer I believe and better too right? Is there a lot of modifications to installing this batt? Is it a lot of work to do? Thanks
  15. PriusCamper
    12,064
    4,896
    Fairly easy... You have to add a longer bolt on the cross bar mounting bracket and slightly longer bolts than it comes with and some washers to sandwich the terminals into place.
  16. Taxi/Limo
    524
    107
    Not to hard My novice questions are will this one https://www.ebay.com/itm/141206981871 Fit in the battery compartment? Will it fry the electrical system on my Prius? Does 55 AMPS or 55 AH simply mean if will take more to drain it? Why do these batteries withstand deep drain and the stock prius batts do not? The one above has screw holes rather than posts how do I attach cables?
    Your info is really helpful Thanks
  17. PriusCamper
    12,064
    4,896
    Yes, 55amp-hours means it lasts longer if you leave the door open or headlights on. Most of the auto store bought ones are closer to 35amp-hours. And because this battery fits in the back corner of the inside of the car, not the engine compartment, you can safely use this type of 12v, which is less expensive because they sell huge numbers of them to power wheelchairs and back up power supplies for personal computers.
  18. Taxi/Limo
    524
    107
    Okay
    How do I attach cables?
    Thanks
  19. Taxi/Limo
    524
    107
    Thanks maybe someone could answer The battery you recommended does not have posts but instead a screw hole. How do I affix the battery cables ? Thanks
  20. bisco
    51,155
    maybe you could get a bolt, nut and washers, and sandwich it together over bare wire, or put a crimp loop (eyelet) on the wire
