What broke in this picture?
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Oct 9, 2024 at 2:30 AM.
  1. douglasjre
    douglasjre Senior Member
    1,947
    669
    Null, NL
    Screenshot_20241009-022738.png Pulled the steering column apart to try and find whatever is loose causing a knocking over bumps and reassembled. It all turned the wheel and something snapped and now the horn doesn't work. Pulled the hornet off. It's still connected but it looks like something in here is must be broken. Car is throwing codes. Haven't had a chance to pull them yet. Which one of these parts has the clock wire?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,374
    6,043
    Columbia, SC
    If memory serves correctly, 84306 should be the clockspring assembly
