what bushings are there in the rear?
Discussion in 'Gen 3 Prius Main Forum' started by csx2002, Apr 1, 2025.
  1. csx2002
    csx2002 New Member
    Fremont, CA 94536
    Hello,
    Can someone list all the bushings in the rear suspension?
  2. Mendel Leisk
    41,463
    That's a tall order.
    You could have a look at the rear suspension page on Amayama. They ask now for "frame number", which you can find (without ID), on the driver's door frame decal, the one with the VIN. It's something like this:
    Model code: ZVW30L-AHXEBK (aka "frame number")
    The above is for a Canadian spec 2010, with build-date August, 2009. Your will probably have the first 5 values the same, but the rest different. Not sure how much it would matter for rear suspension, but worth doing it right.
    Anyways, this is the rear suspension page for the above, more'n likely no different than your frame number::
    Rear spring & shock absorber for Toyota Prius ZVW30L - Auto parts - Amayama
    csx2002 likes this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,154
    565
    Alberta
    2024 Prius Prime
    XSE
    Are they already wearing out?
  4. csx2002
    csx2002 New Member
    Fremont, CA 94536
    yes, bushings are not that expensive as far as I know so I want to replace all of them.
  5. Mendel Leisk
    41,463
    what's the miles?
    Attached has info, torque values.
